help on paint touch up
Old Jul 19, 2006 | 04:24 PM
spiked's Avatar
spiked
Default help on paint touch up
hey everyone. Just chipped a little of the paint off the drivers side door on my victory red 06 coupe.
The chipped paint is only about 1/2 to 1 inch in length located right below where the door latch is.
Is there a way to touch it up or would i have to get the entire door painted?
Thanks for any suggestions in advance.
Old Jul 19, 2006 | 04:34 PM
LesR's Avatar
LesR
What you do depends on how **** you are about your car. Since you read CF, I'd presume you are pretty ****, like the rest of us.
I have touched up my car with the kits you can buy and paint from body shops specially formulated to match your car. There's a little procedure you have to follow to make it look as good as you can.
My eye always goes to that spot that I touched up. Usually most people won't notice it, BUT I DO!!
I pay and have them done professionally. Usually after I get a few, because my car isn't in the shop any longer for 3 than for 1.
Old Jul 19, 2006 | 04:37 PM
teazr1's Avatar
teazr1
If you find a body shop that's extremely good, they can touch it in and you'll never be able to see it. Having my dad own a body shop, I can tell you that it can be done. However I'll warn you that there are a lot of shops that won't be able to get the job done properly and they'll suggest that you have to spot paint it to make it go away.
Old Jul 19, 2006 | 05:03 PM
GM Kid's Avatar
GM Kid
Dang, that's a big chip. Is it as wide as it is long? If so, a hunk of paint that big can't be fixed effectively by a do-it-yourself-er.
Still, you could give it a go. For chips smaller than that, I begin by applying one or more coats of touch-up paint. The final coat should overfill the void a bit, raising up like a little blister. Let it get good and dry (for something large, a day should do).
There's a 3M safe-for-clearcoats rubbing compound I use that you can get at Checker Auto. At my store it's on the paint equipment aisle with sandpaper and stuff, not the wax/polish aisle.
Get a credit card (or similarly sized piece of flexible plastic) and sheath it in two layers of cotton t-shirt, stretching it taut across the plastic. Apply the 3M product to the t-shirt and then use that flat surface to gradually polish down your touch-up. You'll make your best progress as you feel the 3M product starting to haze. It's more "grippy" then--not as fluid and oily as when you first apply it. Go round in circles, then alternate with up-down and diagonal strokes. Wipe off the haze, move to a clean portion of t-shirt and start over.
The trick is knowing when to quit. If you go too far in trying to get the touch-up perfect, you'll end up wearing through the surrounding clear coat. With these larger touch-ups, you also may find that you have little voids or pits in the touch-up paint. Fill 'em, let 'em dry and repeat the above procedure until you're happier with the look.
And if all else fails, have a professional paint your door.
Old Jul 19, 2006 | 05:10 PM
TonyC6Go's Avatar
TonyC6Go
From past experience, do not even try to buy the touch-up paint that you can buy in the small tube from your local GM dealership - it never matches the paint. Instead, go to a local body shop that does paint, and have them get the exact paint match color in a small bottle for you. This way, you have it on hand for future nicks and it matches 100%.
Old Jul 19, 2006 | 05:48 PM
chris36053's Avatar
chris36053
I used this place and got the paint pens, 1 for base and 1 for clear, it was a perfect match for LMB. My scratch wasn't that big though. It might be pretty hard for you to touch that up without some paint experience. Hope this helps.
http://www.paintscratch.com/
Old Jul 19, 2006 | 07:09 PM
spiked's Avatar
spiked
thanks for all the help. you guys are the best.
The chip is more like a scratch. About 1 inch in height and not even a cm in width.
Old Jul 19, 2006 | 07:30 PM
MADinAK's Avatar
MADinAK
St. Jude Donor '06-'07-'08-'09-'10,'14
Customer service with these people was great. The color was perfect.
Old Jul 19, 2006 | 08:13 PM
jayelleseven's Avatar
jayelleseven
didnt he say he had a chip?
Meguiars online forums_
Old Jul 19, 2006 | 08:40 PM
par34n5's Avatar
par34n5
St. Jude Donor '06
Default touchup123
best I have ever used they are on the web
Old Jul 19, 2006 | 09:14 PM
cmb13's Avatar
cmb13
Wow! Sure seems like you know what you're doing. I'll have to bookmark this thread.
Old Jul 20, 2006 | 02:19 PM
Rob4092xx's Avatar
Rob4092xx
GM Kid:
Great info!
I have a metallic silver chip to repair and everytime I try the above, it turns black.
Any advice how to do a metallic chip?
Thanks!
Old Jul 20, 2006 | 03:29 PM
jdavis's Avatar
jdavis
Originally Posted by Rob4092xx
GM Kid:
Great info!
Thanks!
I also have machine silver (67U) and have found it very difficult to get a match. I used the GM touch up paint for my repair. I applied and removed it several times before I managed to get a fair match by using the paint at the bottom of the container rather than shaking it up. When I added clear, it darkened too much. I removed the work and reapplied without clear. Metallic colors are tough to match because the metallic particles do not line up and reflect light the same when brushed on as when sprayed.
To help on paint touch up
