DBS: Possible Solution
Old Jul 21, 2006 | 09:27 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Default DBS: Possible Solution
After 2 years and several incidents of DBS on my 05 6 speed, the dealer may have discovered the problem. The computer stored a fault code for the steering column module which was failing to communicate with the car's main computer. This allowed the car to stay awake. The amount of amps that this would draw would run the battery dead in 2 days, which is the norm for DBS. After starting and turning off the car while hooked up to the computer, a fault code, "column lock failure to communicate" would trigger on every third or 4th shutdown. The new module is coming in from Bowling Green today. This repair will be forwarded to the GM Tech network after 30 days if my car's issues appear to be resolved. I have long felt that DBS was tied into the column lock and maybe this is the breakthough. We'll see.
On a sidenote;The day before this discovery GM Customer Assistance had advised me to "Refer to my owner's manual for proper shutdown procedures on vehicles equipped with a manual transmission." I almost flipped my cork. Anyway, Let's hope this resolves it for me and many of you that have suffered from this.
Old Jul 21, 2006 | 09:40 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Paul,
That's great news. Wow, imagine if you are the person that helped to solve DBS. You'll be a hero, there will be parades, talk show appearances, a spot in the Corvette Hall of Fame.
Seriously, I'm afraid that there are many little quirks in the car that can cause this type of issue. The battery run down protection will ignore too many of these very low current draw issues. I hope that this takes care of your issue once and for all. You'll need to PM me what service department you worked with on this one. It sounds like they may be a keeper. I'm always looking for the best dealers to handle service issues with. Take it easy.
Paul
p.s. Did you go to the Star last night?
Old Jul 21, 2006 | 10:17 AM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
Hi Paul. I believe it is the solution for my car. Wether it solves other people's problems remains to be seen. I didn't go to Star's because of the Tropical Storm starting rain early on the Cape.
Old Jul 21, 2006 | 11:35 AM
Dale_K's Avatar
Dale_K
Maybe I should buy a ODBII code reader and check for something similar.
Old Jul 21, 2006 | 12:20 PM
Fred S's Avatar
Fred S
Sounds promising!
Old Jul 21, 2006 | 12:24 PM
Miaugi's Avatar
Miaugi
Old Jul 21, 2006 | 12:39 PM
VET4LES's Avatar
VET4LES
The A4's have the steering wheel lock also so I don't think that's it but lets hope it is.
To DBS: Possible Solution
