Help!!!
Old Jul 27, 2006 | 07:14 PM
ridnlo's Avatar
ridnlo
Default Help!!!
I am installing a set of SS brake lines and the passenger rear won't thread into the new SS brake line. I can get it to just start, then it pops out when I try to tighten it down. I tried the SS line on one of the other corners and it goes on fine. I then pulled off one of the installed SS lines and tried it on the passenger rear and the same thing happened. The problem seems to be the hard line fitting on the passenger rear. Upon close inspection, I see no damage of the threads. This fitting was a little more difficult to remove than the others when I pulled off the factory lines. What should I try ??? Would a little teflon tape help things go together??
