Wheel weight adhesive residue... How do i remove!!!
Old 07-29-2006, 01:23 PM
c5vette73
c5vette73's Avatar
Default Wheel weight adhesive residue... How do i remove!!!
I had my tires balanced at the dealer because my steering wheel was vibrating at speeds exceeding 70mph. That fixed the problem.
However, when I was washing my car I discoverd that the adhesive residue from the old weights was still there. It is black and thick.
Any recommendations on how to remove it quickly and safely?
Old 07-29-2006, 02:25 PM
patton
patton's Avatar
St. Jude Donor '09
safe : wd40 or avon skinso soft not so safe: starting fluid,2+2 carb spray cleaner
Old 07-29-2006, 02:27 PM
C6 MoneyPit
C6 MoneyPit's Avatar
St. Jude Donor '06-'07-'10, '15. '22-'23
Mineral spirits might do the trick, just be careful.
Old 07-29-2006, 02:28 PM
VET4LES
VET4LES's Avatar
Old 07-29-2006, 02:33 PM
C2Jeff
C2Jeff's Avatar
I find that lighter fluid is a universal solvent.
Old 07-29-2006, 02:37 PM
Buffy
Buffy's Avatar
Stoner's "Tarminator" tar grease and sap remover - this stuff works as well as their "Invisible Glass" glass cleaner, and that's saying something! Goo Gone would be another thing that should be fairly safe.
Old 07-29-2006, 02:48 PM
ModsByMarc
ModsByMarc's Avatar
GOOGONE from hardware store... homedepot.. etc
or alchohol (Jack Danials, Anjeho, Captain Morgan......)
Old 07-29-2006, 02:52 PM
The Clevite Kid
Support Corvetteforum!
The Clevite Kid's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Default Florida solution
Since, like me, you live in Miami, we can still buy chlorinated aerosol brake cleaner at the auto parts store. It is illegal in California and other blue states. This has a lot of perchloroethylene (dry cleaning fluid) and it will take off most organic dirt without harming paint, polish clear coat, or chrome.
Also good for taking spots out of neckties without paying the cleaners $9.95 to clean a lousy necktie.
Old 07-29-2006, 02:57 PM
doctunder
doctunder's Avatar
Really, I would have never thought to use alcohol for anything other than it's intended use......I think your suggestion, although a good one, can be considered some form of alcohol abuse.
Old 07-29-2006, 03:23 PM
talon90
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
with wd40 and GooGone from a post below. I have used these to remove said wheel weight adhesive and they will do the trick with alot of elbow grease.
Old 07-29-2006, 03:31 PM
Zuntov
Zuntov's Avatar
CRC Brake Cleaner and a small nylon brush, WD40, Acetone, etc.
Old 07-29-2006, 05:38 PM
RADRB8
RADRB8's Avatar
GOOGONE...why waste the Capt. Morgan????
Old 07-29-2006, 05:57 PM
Craigster05
Craigster05's Avatar
St. Jude Donor '07-'08-'09-'11-'12
Heat is up, comes off much easier.
Old 07-29-2006, 06:24 PM
c5vette73
c5vette73's Avatar
Thanks to all.
I dedided to use WD40 for no other reason than that I had some. Worked well, but had to give it some elbow grease.
Now off to get me calipers powdercoated.
Old 07-29-2006, 09:15 PM
Bandit1
Bandit1's Avatar
3M Adhesive Remover
Old 07-29-2006, 09:20 PM
PaBlueCoupe
PaBlueCoupe's Avatar
St. Jude Donor '06-'07-'09
Good posts. Actually I need to remove some wheel weight adhesive and remove some spots from some ties, so see you later
Old 07-29-2006, 09:56 PM
emejay
emejay's Avatar
Used Googone last week for teh exact purpose you enquired about, and it worked great.
Old 07-29-2006, 10:10 PM
Z0SLIK
Z0SLIK's Avatar
Old 07-29-2006, 10:11 PM
C2Jeff
C2Jeff's Avatar
Don't be silly: the Capt. Morgan is for celebrating after you use the GooGone!
To Wheel weight adhesive residue... How do i remove!!!
Quick Reply: Wheel weight adhesive residue... How do i remove!!!
