No DBS.......
Old Aug 4, 2006 | 08:29 PM
tv_dir's Avatar
tv_dir
Default No DBS.......
So far, but the car takes a good 2 to 3 seconds (of dead air) before it fires up. Is this normal? Or should I be worried?
--Mike--
Old Aug 4, 2006 | 08:31 PM
johnodrake's Avatar
johnodrake
Moderator
What do you mean "dead air"
Old Aug 4, 2006 | 08:35 PM
tv_dir's Avatar
tv_dir
Sorry.....that's a radio term for "silence"
Old Aug 4, 2006 | 08:38 PM
timd38's Avatar
timd38
Mine does it also. You push the start button and it takes about two seconds before the noise starts.
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
So you're saying that you press the start button and get dead silence for 3-4 seconds before anything happens?
Old Aug 4, 2006 | 08:40 PM
tv_dir's Avatar
tv_dir
Actually about 2 or 3 seconds...but yea.
Old Aug 4, 2006 | 08:42 PM
'06 Quicksilver Z06
I'd try changing the FOB battery.
Old Aug 4, 2006 | 08:45 PM
tv_dir's Avatar
tv_dir
Dang I didn't even think of that! That would probably be the easiest way to tell. Thanks.
--Mike--
Old Aug 4, 2006 | 09:09 PM
Hoonose's Avatar
Hoonose
--Mike--
Never heard of this. Mine is almost 'instant on'. Does yours crank for 2 seconds then start? Or does just nothing happen for 2 seconds?
The new switches take 2 extra seconds to shut down I heard. Is this an '07?
Old Aug 4, 2006 | 09:21 PM
tv_dir's Avatar
tv_dir
'05 16,000 miles, MN6........Does nothing, nada, zippo for 2-3 seconds then starts. It's almost as though the battery is on it's way out...but not yet.
Old Aug 4, 2006 | 09:22 PM
timd38's Avatar
timd38
Same here.
Old Aug 4, 2006 | 09:28 PM
tv_dir's Avatar
tv_dir
Originally Posted by timd38
Same here.
Has yours been doing this for a while?
I noticed it about a month or so ago. All the DBS threads here has made me a little paranoid every time it doesn't crank over immediately
Hoonose's Avatar
Hoonose
Is this a new problem? If so, it may well be a battery problem. Or maybe a bad ground. I'd have it checked!
Giving it a thorough charge or even jumping from another car may give you a quick answer.
Old Aug 4, 2006 | 09:31 PM
PaBlueCoupe's Avatar
PaBlueCoupe
St. Jude Donor '06-'07-'09
Try pushing the clutch all the way to the floor!!
Old Aug 4, 2006 | 09:32 PM
tv_dir's Avatar
tv_dir
About a month now. Just haven't had the time to take it in. I guess if I don't want to get stuck, I need to find the time.
Old Aug 4, 2006 | 09:33 PM
tv_dir's Avatar
tv_dir
DUH!
Old Aug 4, 2006 | 09:38 PM
gsport's Avatar
gsport
i'm on my second C-6 and both of them had a delay before the starter actually started to do something... i assume it's normal
To No DBS.......
Old Aug 4, 2006 | 09:53 PM
Savage C6's Avatar
Savage C6
My 07 does the same thing but not 2 to 3 seconds...maybe like 1 second at most. I noticed that all three of the 06's I test drove before ordering my 07 did the same thing. Sounds normal to me.
Old Aug 4, 2006 | 09:56 PM
fullcontrol's Avatar
fullcontrol
Paid Senior Member
Mines like a light switch... instant on
Old Aug 4, 2006 | 09:58 PM
gsport's Avatar
gsport
hmmmmmm very interesting......
