Need Help Quick!!
Old Aug 7, 2006 | 05:51 PM
steppindown's Avatar
steppindown
Default Need Help Quick!!
Just bought 07. Wife just called. Says drivers door does not close all the way and window not working right. Are the 2 related? How do you reset the windows to drop down when you open door and then go back up into gasket when you close it?
P.S. IT'S RAINING and the interior is getting wet!
Old Aug 7, 2006 | 05:57 PM
whitesox05's Avatar
whitesox05
DO NOT Roll up the windows while the doors are open. The windows are indexed to automatically roll down slightly upon exit or entrance.
Old Aug 7, 2006 | 06:00 PM
Vette_DD's Avatar
Vette_DD
To reset the window indexing (okay while the doors are open), raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Fixed.
Old Aug 7, 2006 | 06:01 PM
PillRoller's Avatar
PillRoller
I'd be calling the dealer!
Old Aug 7, 2006 | 06:02 PM
Vette_DD's Avatar
Vette_DD
Try resetting the window indexing first.
Old Aug 7, 2006 | 06:03 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Old Aug 7, 2006 | 06:06 PM
whitesox05's Avatar
whitesox05
Wanted to get my intial response out there so you knew what to do. If the door is not shutting you most likely rolled up the windows with the door open and then are trying to shut the doors. If you do that you should hear a repeating bell alarm to indicate that there is something wrong, meaning you left accessory mode on, or left your key fob inside the car while exiting, or rolled up your windows with the doors open. The door glass fits inside the top for a better fit. You may need to setup your window indexing if this does not fix the problem but you should be able to lower and raise your windows via the power switch in the meantime.
Old Aug 7, 2006 | 06:41 PM
steppindown
Default Re: Need Help Quick!
I got the window timing reset and all is fine. Thanks for the help!
Old Aug 7, 2006 | 07:12 PM
nuvetteowner's Avatar
nuvetteowner
Okay now go get the paper towels and dry it up inside!
Old Aug 13, 2006 | 02:59 PM
rwpatte's Avatar
rwpatte
Originally Posted by talon90
Hey, it worked for me too. Thanks.....
To Need Help Quick!!
