Balky Tranny
Old Aug 12, 2006 | 12:00 AM
dbirdhouse1's Avatar
dbirdhouse1
Default Balky Tranny
It's my '05 6 sp manual......about 25% of the time getting it into first either requires either a very serious (often repeated) shove or I just take off in second to avoid the pleasant sound of honking horns....
Occasionally reverse can be similarly tough
She's got all of 3400 miles......
Is it something I said?
Thanks in advance for your collective wisdom.
Old Aug 12, 2006 | 12:03 AM
Vette_DD's Avatar
Vette_DD
Have you tried going to 2nd, then back to first? Some had a problem if they were trying to go from neutral to first. Others have reported the same problem. Don't know about reverse. Didn't have any problems with mine when I had it.
Old Aug 12, 2006 | 12:08 AM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Either that or re depress the clutch.
Old Aug 12, 2006 | 12:32 AM
dbirdhouse1
yup, both suggestions work most of the time....just wondering if it:
a. Will loosen up some more
b. Consider changing tranny fluid
c. Cuss repeatedly
Old Aug 12, 2006 | 12:48 AM
Dave Tracy's Avatar
Dave Tracy
I have an 05 with a 6 speed. Have had the same problem. The car is currently at the dealer and wanted this and several other items looked at. So far the response is "the transmission works fine". I have been pushing the issue and will let you know if I'm successful.
Old Aug 12, 2006 | 02:55 AM
dbirdhouse1
I appreciate your responses, and thanks to Dave especially
Old Aug 12, 2006 | 08:29 AM
Coastal Boot's Avatar
0Coastal Boot
Former Vendor
It's called first gear lock out and I had the same problem. There is a TSB out and dealer fixed the problem.
I don't know the TSB# but I do know it's called first gear lock out.
Dealer repaired and is fine now.
Old Aug 12, 2006 | 08:48 AM
mickmike1's Avatar
mickmike1
Default Balky tranny
I had the same problem and replaced the transmission fluid with Royal Purple Synchromax manual transmission fluid. Saw an immediate improvement. Still not Porsche smooth, but much better. Search the forum on this product for more info.
Old Aug 16, 2006 | 07:57 PM
Dave Tracy's Avatar
Dave Tracy
I haven't forgotten about you. I have yet to get my car back from the dealer. It has been 2 weeks. I found on the forum search a posting by houston_aggie dated 8/13/06. I copied it and will forward it to the dealer. I'll let you know.
Old Sep 4, 2006 | 11:49 AM
Dave Tracy's Avatar
Dave Tracy
Just got the car back. 4 weeks at the dealership. Nothing was done to the transmission. Told it was "operating as designed". I have a VP friend at GM in Detroit. He recommends going to another dealership and if unsuccessful, he will get involved. I'll keep you up to date.
Old Sep 4, 2006 | 12:04 PM
shortski's Avatar
shortski
From the FAQ in the General Discussin Area of the Forum lot of good stuff check it out.
http://forums.corvetteforum.com/showthread.php?t=927981
Here's the details
http://forums.corvetteforum.com/show...9&postcount=19
Old Sep 4, 2006 | 12:09 PM
johnodrake's Avatar
johnodrake
Moderator
Had that problem with the C5. Royal Purple did not make it go away (good stuff otherwise though!)
Double clutching always worked for me.
JD
Old Sep 4, 2006 | 12:28 PM
LOS ANGELES PI's Avatar
LOS ANGELES PI
I used to have same issues. I switched to a shifter by MTI racing. Best 200.00 mod out there. Shifitng is short and firm. No more missing third from second and racing in the twisties on a short apex, it slaps down into first as easily as 6th to fith.
Change your shifter. people also like the Hurst and the Calloway.
Old Sep 4, 2006 | 12:36 PM
flaskier99's Avatar
flaskier99
If you have any problem with the dealer print this out. It should shut the dealer up immediately. Please notice the PIP #'s
Old Sep 4, 2006 | 12:37 PM
GN1270's Avatar
GN1270
Welcome to the world of the T56 transmission. They are known for that problem, and it should get worse when it gets cold outside. My CTS-V had the same problem> I'm pretty sure I read that the Vuper uses the same tranny and also has those problems. So far my 07 is stiff, but not hard to get into gear.
Old Sep 4, 2006 | 01:49 PM
Hoonose's Avatar
Hoonose
There was a bulletin on this way back. If you encounter trouble engaging 1st more often than 10-15% (I think) of the time, then it is considered abnormal, and there is an adjustment that can be made. This is common with any manual tranny.
Old Sep 5, 2006 | 01:21 AM
dbirdhouse1
This is exactly what I had done to mine as well..........kudos to Friendly Chevrolet in Olympia, WA
To Balky Tranny
