CAGS (skip-shift eliminator) = check engine light?
Save yourself 20 bucks and make it more reliable by just sticking a bare 2.2K Ohm resistor in the female CAGS connector. The link above is step by step how to do it, it's on an F-body which is the same trans as a Vette.
F-body enthusiasts have been doing this forever and I've never heard of a problem. I bought a pack of six resistors from Radio Shack many years ago, used 4 on my F-bodies through the years and the last 2 on my last 2 vettes. Not a single one ever had a problem.
I've seen and heard of countless problems with the aftermarket modules and resulting warranty hassles. All they are is the exact same resistor with more connections, solder joints, wire ... to go bad. The problem with the Vette crowd is the module is more expensive, so it must be better. Trust the F-body crowd that gravitates more to the cheaper, simpler, dead nutz reliable method.
The dealer is full of sht if they are telling you they can't read pcm data with a bad CAGs defeat module. All that thing can cause is a code :
DTC P0803 Skip Shift Solenoid Control Circuit
All other PCM data will be accessed perfectly.
To clear this code yourself, plug the OEM CAGS harness back in. 3 drive cycles with the problem gone will turn off the MIL lamp. 40 drive cycles with the problem gone will erase the History code. Then throw that junk module away and stick a resistor in there, you'll never have to touch it again.
