HELP... elec. problem...
i know, i know, i'm kicking my own ***. just one of those things on one of those days. anyway, i have checked the fuses under the toe board and no luck there. they are good. just hoping some of you guys got any ideas...
looks like there is two fuses that power the HVAC module... (A/C controls)
HVAC/PWR SEND
ISRVM/HVAC
both are 10A fuses... from BCM (i would guess thats the passenger floor area - Blower fuse is under hood)
Plan A: if you can find get a hold of someones (a friends Vette) HVAC module swap it out to test if it works.... buy the part and change it yourself.....
i would think the dealer will find the water damage and charge a pretty penny to swap it out....
Plan B: take it apart... clean and dry it out.... take to dealer... fix under warranty
Plan C: take you chances... drop off at dealer....
Plan D: trade it for Z06
i personally like Plan D!!!
hope your able to get your A/C working soon.... good luck
I would be screaming too
Good luck... I am sure someone can give you some advice.
