Bose automatic volume control
Old Nov 14, 2006 | 08:29 AM
  #41
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Originally Posted by rothchilds
it sucks, plain and simple.
I have had 4 other cars with the old fashioned SCV that worked fine. They "FIXED" up the new systen so its worthless and best bet costs more
Old Nov 14, 2006 | 08:38 AM
  #42
JVM225's Avatar
JVM225
St. Jude Donor '06
Originally Posted by johnodrake
Mine seem to work, go figure....
Old Nov 14, 2006 | 10:31 AM
  #43
Monts's Avatar
Monts
I think the Bose system is just fine, except that the automatic volume compensation system is inadequate. In theory, if the system was working properly, you would not realize it is working. That's where I detect a little confusion in this thread.
There is a difference between "I can't even tell it's working because it's working so well I don't notice the changes in volume", and, "I can't tell it's working so I have to manually adjust the volume to compensate for speed and noise conditions".
This is then a common problem for both NAV and non NAV Bose systems. I'm surprised that Bowling Green or Bose has not addressed this problem after three model years no less.
Has anyone followed up with the factory or Bose?
Old Nov 14, 2006 | 11:10 AM
  #44
Mel 2001's Avatar
Mel 2001
Originally Posted by SDCEB
The Audio Pilot only works at low volume levels. It is no big deal, I like the Bose system. Most people either love, or hate Bose, it is up to you.
Same here
Old Nov 14, 2006 | 11:20 AM
  #45
Vetti3's Avatar
Vetti3
Works fine on mine. I can definitely tell that the volume goes up when the speed increases.
Old Nov 14, 2006 | 11:23 AM
  #46
Monts's Avatar
Monts
So if you open your windows while you're driving, are you saying you do not have to adjust the volume manually? If so, I don't believe it or you are very lucky!
Old Nov 14, 2006 | 01:55 PM
  #47
anothercrisis's Avatar
anothercrisis
St. Jude Donor '06-'07-'08
On my 99 Tahoe the auto volume control is speed sensitive and works fairly well. On my 05 C6 the auto volume control is "more sophisticated" and supposedly reacts to ambient noise and is worthless!
anothercrisis
Old Nov 14, 2006 | 02:07 PM
  #48
TonyC6Go's Avatar
TonyC6Go
Originally Posted by Indy-hp
The Speed-sensitive Volume Control in my C5 worked great at the second to highest setting. It raised the volume to compensate for the increase in tire noise from an increase in speed almost perfectly, and I got used to never having to touch the volume. The Bose Audio Pilot in my C6 3LT does not perceptably raise the volume for the increase in tire noise from speed. Honestly, I can't tell that it's doing anything, and I have to up the volume manually to hear the stereo as speed increases...
My C5, which had I believe had 3 levels of Speed Sensitive Volume Control, was much better. The C6, I agree, is a piece of crap for the price we pay for this car.
Old Nov 14, 2006 | 04:17 PM
  #49
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
"No highs, no lows, must be Bose!"
The automatic volume control on my 2006 Coupe with nav/XM definitely works, but no better than the simpler system did on my C5. Maybe not quite as good.
