Spare Key
Old Aug 30, 2006 | 12:57 PM
mountainlover's Avatar
mountainlover
Default Spare Key
I normally carry spare house and vehicle keys in my wallet. Has anyone tried removing the palstic/rubber chunk at the top of the factory key, so it can fit in a wallet easily ? Is there a metal portion left on the top of the key that can be used to provide enough of a grip on the key to use the emergency unlock at the rear hatch ?
Old Aug 30, 2006 | 01:23 PM
Jinx's Avatar
Jinx
I did this to my 2005 spare key, using a Dremel. (I made quite a mess.)
The keyring hole is plastic only, so you will need to drill/punch a new hole if you want it on a ring.
.Jinx
Old Aug 30, 2006 | 01:29 PM
shopdog's Avatar
shopdog
Rather than modify the original key, just have a hardware store cut you a duplicate.
Old Aug 30, 2006 | 01:31 PM
AmmoVet's Avatar
AmmoVet
I had a spare made, then removed the plastic part from the spare and put the key in a special credit card holder and store it in my wallet. Works well, visit your local key and lock speciality store!
Old Aug 30, 2006 | 01:45 PM
Hoonose's Avatar
Hoonose
Sheesh! That exact thing came with my C5!
Old Aug 30, 2006 | 06:24 PM
calemasters's Avatar
calemasters
The plastic head cover comes off easy. I just cut it off with a razor blade.
Old Aug 30, 2006 | 10:00 PM
su8pack1's Avatar
su8pack1
Anyone remember when GM used to send you the plastic keys in a little credit card sleeve that fit right in your wallet. I still use mine, but it now has some metal keys in with them.
Old Aug 30, 2006 | 10:51 PM
Atomic Punk's Avatar
Atomic Punk
To Spare Key
