What does this mean?
Old Sep 6, 2006 | 05:12 PM
lexaudio's Avatar
lexaudio
Originally Posted by JFTaylor
It means you're the winner
I get that everyday.
LEX
Old Sep 6, 2006 | 05:57 PM
jabez's Avatar
jabez
Wait....I wanna win too.
Old Sep 6, 2006 | 11:10 PM
Shawn S's Avatar
Shawn S
Originally Posted by su8pack1
It's the job number assigned at the factory. If you have your build sheet you will see they match the job number in the lower right corner.
Yes...
My tires were stamped with 2880 and you can see on my build sheet in the lower right hand corner, it's the same four numbers.
Old Sep 6, 2006 | 11:21 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
LEX
Lucky guy!
Old Sep 6, 2006 | 11:55 PM
steveo242's Avatar
steveo242
Originally Posted by lv2jmp
If you ever get the chance to tour the factory, you should make the effort. It is an amazing experience; and all the better when you can see your own car being built.
Old Sep 7, 2006 | 12:49 AM
Vasta's Avatar
Vasta
St. Jude Donor '06-'07-'08-'09-'10-'11-12-'13-'14-'15-'16
LEX
I was going to post my Playboy "Girls Next Door" picture. I took that picture when I was looking at my car before they detailed it.
Here's a picture of my front tire with #0734 on it. So I went up stairs just now and pulled my build sheet and sure enough it's the same last four numbers. Check out the tire.
I think I'll throw in the Playboys girlz anyway
Old Sep 7, 2006 | 01:22 AM
73-84 IMSA Widebody's Avatar
73-84 IMSA Widebody
It's your new "LUCKY NUMBER"
Old Sep 7, 2006 | 10:56 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Originally Posted by Tommy D
Lucky guy!
Old Sep 7, 2006 | 11:00 AM
AFVETTE's Avatar
AFVETTE
Originally Posted by Shawn S
Yes...
Sure nuff. Learn something new everyday.
Tom
Old Sep 7, 2006 | 11:37 AM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Default Back In The Good Old (St. Louis) Days...
The sequence numbers once only went to 500 or 999, and then they would start over again. You could have many cars with the same sequence number any model year. These days, it looks like the sequence numbers NEVER repeat, they just keep increasing as production continues.
If you restore an old Corvette, you will find the sequence number marked in grease crayon several places on the car to facilitate getting the right body pieces together (convertible or coupe) and the right options installed. Some of you have noted the same on your new C6s.
The sequence number on the tires is not new info, but congrats to lv2jmp for having the earliest, most complete and accurate answer. And, NO, lv2jmp, you don't win anything...this is all the prize you're going to get.
Old Sep 7, 2006 | 11:33 PM
Tommy D's Avatar
Tommy D
Yea
Old Sep 8, 2006 | 05:22 PM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
OK Ben
