i HAVE A C6 WHICH I HAVE A NAVIGATION SYSTEM AND ALSO A DVD SLOT TO PLAY THE DVD'S. I'M NOT SURE IF MY DVD SYSTEM DOESN'T READ THEM OR I JUST DONT HAVE THAT INSTALLED IN ORDER TO PLAY THEM. ANYONE HAVE AN IDEA OF WHAT I SHOULD DO ?
Watch the DVD that came with the car...if still have questions...read owners manual.
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Does your navigation system work ok? If so, then you must have the Nav DVD inserted correctly. If not, then put it into the other slot.
Wlhen you open the Nav system by pushing on the button below the screen, you will see two slots. The Nav DVD goes in one of them and your music DVD goes in the other. They are marked with symbols and you should be able to tell which is which.
If the DVD's are inserted correctly...i.e. in the right slots and not upside down...and neither works, I'm not sure what is wrong. As mentioned above, you might also read the Owner's Manual. With the Nav system you only have one slot for a music DVD.
i didnt seen no caps lock button. ? But i did see that my dvd for navigation and still no works on the actual dvd's only on the navigation cd. Im going to call chevrolet or read manuel
Are you trying to watch movies? The dvd slot is only for the nav dvd.
The "DVD" slot is ONLY for the Navigation disk (DVD) It will not play movies no matter how hard you try.) Just so you will know. Typing a message like your's in all capital letters is viewed as you are yelling on an internet forum. That is why people are asking you to stop doing it. The CD slot below it will play audio CD's both purchased and created at home. The DVD slot is for the Navigation DVD that came with the unit.
