check oil level
Old Sep 14, 2006 | 08:19 AM
AMERDRM's Avatar
AMERDRM
Default check oil level
The second day after picking up my 2007 vert, the "Check Oil Level" message came on. Took it to the dealer and the services manager stated the sensor is on national backorder meaning there is a lot of problems with this sensor. Has anyone elce experienced this problem on a C6.
Old Sep 14, 2006 | 08:35 AM
3and8fan's Avatar
3and8fan
St. Jude Donor '07-'08-'09-'10-'11
No, I picked up my LMB 07 coupe at the Corvette museum last Friday and drove 900 miles home. Didn't use a drop of oil either.
Old Sep 14, 2006 | 08:36 AM
robertpel9's Avatar
robertpel9
I have put about 900 miles of mostly stop and go driving on my 2007 C6 and no DIC messages about oil and the level is still the same as when i picked it up
Old Sep 14, 2006 | 09:45 AM
k-line's Avatar
k-line
Unless you drove 1000 miles a day i'd say there wasn't enough oil to begin with. That's strange most dealers overfill the oil not underfill. The day i got the check oil message was the first sighn i got one of the oil guzzlers. About 1 1/2 quarts per 2000mi. I have not heard of any issues with that sensor.
Old Sep 14, 2006 | 10:27 AM
robertpel9's Avatar
robertpel9
Mine was overfilled fromt he factory as well. It's between 1/4-1/2" above the top mark and i am just going to leave it there
Old Sep 14, 2006 | 02:32 PM
mountainlover's Avatar
mountainlover
No problems here with sensor. Approaching first oil change with over 11K miles. Use only about 1/4 quart.
Old Sep 14, 2006 | 03:31 PM
VET4LES's Avatar
VET4LES
No problem that I have heard of.
Old Sep 14, 2006 | 07:22 PM
calemasters's Avatar
calemasters
Ask the dealer to upgrade the order to a **** case.
Old Sep 16, 2006 | 05:20 PM
Colovette's Avatar
Colovette
I've received this DIC warning twice in the last six months; once at startup after driving some distance and the other as I was shutting down after driving around town. Each time I checked the oil level and found it to be completely full. Figured I'd add to the list of things whenever I get the time and I'm in the proper mental state to deal with the service department. Please let me know what you find find out.
Old Sep 16, 2006 | 05:28 PM
shopdog's Avatar
shopdog
Yes, I had the oil level sensor in my car fail at 500 miles. Please note carefully that the troubleshooting chart in the shop manual is wrong. It has NO/NC backwards, and a tech following that guide will misdiagnose the problem. The wiring diagram is correct, however, and will lead the tech to the proper conclusion if you can convince him to follow the diagram instead of the troubleshooting chart. (Took me several tries to get the tech to understand this.)
Old Sep 17, 2006 | 07:02 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
My '07 coupe had a TPW of 07/17, took delivery on 07/31, and now has about 2,500 miles on it. I have not had to add any oil (checked level yesterday) and have had no false low oil warnings.
To check oil level
