Changing Car Battery
Old Sep 18, 2006 | 11:10 AM
cksrick's Avatar
cksrick
Default Changing Car Battery
Is there an easy way to keep the computer powered up when changing the car battery?
Old Sep 18, 2006 | 11:31 AM
Old Coot's Avatar
Old Coot
Good question. I wonder if you could use one of those battery chargers you plug into the cigarette lighter?
Old Sep 18, 2006 | 11:32 AM
dbradley's Avatar
dbradley
I've seen adapters that plug a rechargable 9V into the cig lighter so you don't loose settings....... not sure that would do the trick though on our cars.
Old Sep 18, 2006 | 11:33 AM
Lee6's Avatar
Lee6
excellent question......
i will be looking to replace my 2-year old battery soon......
anyone know?
Old Sep 18, 2006 | 12:11 PM
TexJeep's Avatar
TexJeep
There are some guys on the forum who are really savvy about this and I'm sure you'll get good information. When I had my battery disconnected, the only issue I had with saving settings, etc. was window indexing. That took about 30 seconds and I was good to go.
Old Sep 18, 2006 | 12:18 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
What are you worried about loosing? As far as I've experienced the only setting that gets lost is window indexing and that only takes 6 seconds to restore.
Paul
Old Sep 18, 2006 | 02:32 PM
Mel 2001's Avatar
Mel 2001
The cig outlet with 9 volt bat worked on my C5. Don't know about the C6.
Old Sep 18, 2006 | 04:13 PM
vetterun's Avatar
vetterun
I've disconnected the battery three times for about 10-minutes each time with no problem. All settings, as far as I can tell, were saved. Maybe some radio station preferences lost - not sure.
Old Sep 18, 2006 | 04:57 PM
C8-Vette's Avatar
C8-Vette
Paul
Old Sep 18, 2006 | 04:59 PM
C8-Vette's Avatar
C8-Vette
Radio settings are not lost due to flash memory. Only the window indexing goes. Easy and fast fix.
Old Sep 18, 2006 | 06:14 PM
VET4LES's Avatar
VET4LES
Paul
The indexing takes less time than installing a by pass 9V battery.
Old Sep 18, 2006 | 06:27 PM
timd38's Avatar
timd38
The lighter charger won't work. I hook a battery charger to the + cable and the other to ground and have a person hold the + cable while the old battery is removed.
Old Sep 18, 2006 | 07:25 PM
RADRB8's Avatar
RADRB8
Old Sep 18, 2006 | 07:37 PM
avidedit's Avatar
avidedit
Dumb question I'm sure, but what is window indexing?
Old Sep 18, 2006 | 07:42 PM
Miaugi's Avatar
Miaugi
The way the C6 windows "drop down" when opening the doors, and then go "back up" after the door is closed.
Old Sep 18, 2006 | 07:43 PM
Fastronaut's Avatar
Fastronaut
CF Senior Member Emeritus
When you get in/out of a C6, the windows roll down an inch or so. That's indexing. It helps with ease of door opening and closing.
Old Sep 18, 2006 | 08:02 PM
avidedit's Avatar
avidedit
Cant figure why the computer would lose indexing info... they drop the same distance each time. How do you reprogram and what happens if the shop doesnt do this and someone slams the door shut with the window full up?
To Changing Car Battery
Old Sep 18, 2006 | 08:05 PM
talon90's Avatar
talon90
NCM Ambassador
From the owners manual:
Power Window Initialize
After a power reconnect such as battery replacement,
the window index-up feature will not function until
the system is initialized. Once power is restored,
do the following:
1. Close the door.
2. Raise the window by pulling up the switch.
3. Hold the up switch for three seconds after the
window is closed. Release the switch.
4. Hold the up switch again for three seconds
and release
The window will hit the gasket and not close. You could damage the window.
Old Sep 18, 2006 | 08:14 PM
avidedit's Avatar
avidedit
Thanks... wot a great forum !
Old Sep 18, 2006 | 08:29 PM
LS WON's Avatar
LS WON
Dealer disconnected mine and 2 functions had to reset themselves after driving as they went to zero one was the right TPS monitor and the other was a mileage can't remember but eventually both of these reset themselves while driving.
