Over the last month, my C6 has begun doing something odd. I'm not sure it is really a problem, but has anyone else seen this?
If the car sits for a day or more, the first time I push in the clutch, it is quite stiff and takes quite a bit of pressure. The next time (and all subsequent times) the pressure required is normal.
Anyway, I'll have it looked at when I get the oil changed this month. Just curious if anyone else has noticed. BTW - my car is about 20 months old.
A cheap fix might be to check the level of hydralic fluid in the clutch cylinder and add if necessary. Also it may be a good idea to suck out the old fluid and replace. This should be done a number of times. Bleeding is the best, but it impossible to get to the clutch bleeding valve without a hassel. Sounds to me your fluid got a little low and air MAY have gotten into the system.
Let I know what solves the problem.
