Delaminated Roofs????
Old Sep 20, 2006 | 08:49 PM
JWall64's Avatar
JWall64
Default Delaminated Roofs????
I am looking at a 2007 coupe. The car is out of state about 2.5 hours away. It's a early build (built in July). I am pretty sure it has the old poly roof panel with "the triple bonding" and not the SMC roof. I had the dealer pull back the headliner, and he said it was black underneath. I am getting a pretty good deal on the car (GMID and $250 cashback from GM plus $2500 from my old GM Card). Should I wait and get a SMC roof or will "the triple bonding" roof panel be fine.
Old Sep 20, 2006 | 08:54 PM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
The "triple bonding" is said to have cured the problem but it was an expensive fix. The SMC roof is cheaper to produce and that is why GM changed. It is 3 pounds heavier. My car was built with the old roof and I am glad it was. That extra 3 pounds does make a difference to some people.
Frank
Old Sep 20, 2006 | 09:03 PM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
My roof was replaced with the triple-bonded one and it has held up ok so far even in some pretty hot weather.
Old Sep 20, 2006 | 09:12 PM
blaine's Avatar
blaine
I have an 06 and the original roof failed after about 6 months. They filled it with foam and made a horrible mess all over the headliner on the roof. Got a replacement and it is failing now, i havent even let them install the headliner on this one..when i have time i need to go back to the dealer and see if they can order an SMC roof. Who cares if it weighs more.. i need to lose some weight anyways
Old Sep 20, 2006 | 09:36 PM
MaNiFeSt's Avatar
MaNiFeSt
i just picked up my car from the dealer today and they put the new roof on it. they had to order it, then paint it to match the rest of the body..
i asked the guy if it was the new roof and he said thats the one gm sends out when there is a delamination issue. They also replaced some bushings that were causing some creeking noises..
I hope they gave me the new roof, but i'm really not sure how i can tell if its an smc roof or just a new one with all the foam and crap?
Old Sep 20, 2006 | 10:25 PM
Zymurgy's Avatar
Zymurgy
Moderator
1) Weigh it. New roof will weigh right around 24 pounds. The old roof weighs around 21 pounds.
2) Gently peel back a corner of the liner. Underside of top should be a light color for the new roof versus a dark color for the old roof.
3) Check part number on repair order. New roof has a different part number from the old ones.
To Delaminated Roofs????
