Any pointers when looking for custom rims?
Old Sep 23, 2006 | 12:00 PM
jetboatcapt's Avatar
jetboatcapt
8th Gear
Default Any pointers when looking for custom rims?
Was thinking of replacing C6 wheels with custom or aftermarket wheel. I have googled it but have not found too many choices. Any ideas?
Thanks in advance.
Old Sep 23, 2006 | 12:33 PM
CQRT's Avatar
CQRT
Look in the Forum's vendor sections . . .there's a ton of good stuff and decent prices
Old Sep 24, 2006 | 08:37 AM
jetboatcapt
8th Gear
Tried that. Just not alot of selection for vettes, I guess. Thanks for the thought.
Old Sep 24, 2006 | 08:46 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Thanks in advance.
1) Get ready to pay a hefty Corvette tax. 2) Save the boxes. You'll need them, believe me. 3) If you buy powder coated rims, make sure you have a source for touch up paint. 4) Watch the for sale section of the forum. There are always used rims for sale from forum members (see # 2). 5) Research ! Research ! Research ! I cannot stress this enough. It will save you a lot of grief and aggravation. I speak from experience.
Old Sep 24, 2006 | 01:00 PM
vertC6's Avatar
vertC6
KNOW YOUR OFFSETS! Before you dump 3 to 7k into a set of wheels you must know what you are buying. Nothing will **** you of more than to dump that kind of money and have you wheels sticking out, to far in, or rubbing. Go to Tom Z's website read about offsets and know what you want to buy, don't let a wheel company tell you what you need, more often than not they are wrong and your out of luck. PM me if you need more help.
B.J.
Old Sep 24, 2006 | 01:18 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Money-saving suggestion:
Forum members have a lot of posts about vibration problems with aftermarket wheels, virtually none with factory wheels. Think carefully before dropping big bucks into an appearance mod that may cause mechanical problems.
Old Sep 24, 2006 | 06:00 PM
dalinone's Avatar
dalinone
Default VertC6 - wheels
verteC6: love your wheels. Are they WCC forged 946's? Wheel sizes? Any trouble with the stock fit? Advice?
Thanks!
Old Sep 24, 2006 | 06:07 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
B.J.
How true, how true. Another known truth from the TX contingent
Old Sep 24, 2006 | 08:39 PM
vertC6's Avatar
vertC6
Thanks!
Yes they are 946's but no they are not on my car... yet. I have got it narrowed down to 2 wheels now, the 946's or the Vellano VSH brushed
Old Sep 24, 2006 | 08:45 PM
Paul Scarpelli's Avatar
Paul Scarpelli
The advice to pick a wheel with the appropriate offset is spot on. Don't fall in love with some "rims" that look "awesome" and don't fit. It's a performance car...not lawn art.
And pick wheels that are lighter than stock to reduce unsprung weight. The car's response will be much better, and it may not slam over potholes and expansion cracks like it does now. Our cars feel heavy, even though they aren't, because of the high unsprung weight.
I am assuming you're changing wheels for both the looks and a performance upgrade...
Old Sep 24, 2006 | 09:38 PM
Gearhead Jim
St. Jude Donor '13
I've kept the stock wheels, but most weights I've seen posted show the aftermarket wheels as being heavier than GM. I'd be hesitant to use ones that were lighter, Dave Hill was a real freak about reducing weight and I expect that it would be difficult to make wheels that were lighter than stock but still acceptably strong. Not impossible, but beyond the reach of "Dave's Live bait, Body Piercing, and Custom Wheels."
Old Sep 24, 2006 | 09:44 PM
BEZ06's Avatar
BEZ06
Thanks in advance.
Take a look at forum vendor Complete Custom Wheels (CCW). They make incredibly strong and beautiful wheels at a good price. Tell them what car you want them for and they will make sure you get exactly the size/offset you need.
www.ccwheel.com
I like their racing wheel you see on the homepage of the website - the Corsair. Their "Wheels Profile" page doesn't show the Corsair, but I think it would make a great street wheel.
Bob
Old Sep 24, 2006 | 10:01 PM
BEZ06's Avatar
BEZ06
I live in Daytona and went by CCW to take a look at their wheels. I got a tour of the place and was very impressed!
They start out with a 109 pound ingot of forged aluminum and have a huge press that squashes it down into a mushroom shape. From there they use their CNC milling machines to carve out the type of wheel in the size you want.
The end product is an about 22 pound wheel (about the weight of the stock C6 wheel, I think), but incredibly strong. They can put a satin finish or a mirror polish finish on them.
They load all the left overs from the machining process in a semi-trailer and about every 2 weeks send 36,000 pounds back to the foundry to be recycled.
Strong, beautiful, and made in America!
Bob
Old Sep 24, 2006 | 10:04 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
True... but there are other causes for this besides defective wheels. One common cause is not removing the stud retainer clips, which serve no purpose except to keep the brake rotor on the car as it goes down the assembly line. Stock wheels are counter-bored at the stud holes, so it makes no difference whether the clips are there or not. Not so with most aftermarket wheels though. The clips will prevent the wheel hub from seating squarely against the rotor hub, thus causing wobble. Another common cause is mounting non-hub-centric wheels onto a Corvette (i.e., depending upon snugging the lug nuts uniformly to center the wheel onto the hub). Although this can work, it often doesn't. There are hub-centric adapters available for many applications to solve this issue.
HTH!
Old Sep 24, 2006 | 11:34 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
Another thing about wheel weights to remember is that"most"of the time,the consumer is increasing wheel diameter and/or width.
Both of these changes add to mass and therefore weight.
Remember also that Forged wheels are generally more expensive,but are also lighter AND stronger than the cheaper cast wheel.
And Yes, CCW is the BOMB! Best bang for the buck!
A set generally runs @ $2,500 whereas many ,if not all,other forged wheels come in at the $3,800+ up to 5K!
ccwheel.com
BTW, my 19" wheels ride are smooth as silk
EDIT: I know these are c-5's, but this link will give you an idea on all the types of wheels available out there....give it a look
http://forums.corvetteforum.com/show....php?t=1504667
To Any pointers when looking for custom rims?
