What would you think?
Old Sep 25, 2006 | 08:57 AM
ajsjr's Avatar
ajsjr
Default What would you think?
Not too long ago the dealership replaced the clutch packs on my 06, C6 auto. When I got the car back, I noticed that the car had been driven 15 miles, the oil percentage had gone from 94% to 89%, the fuel was down two ticks and the avg mpg had gone down from 23 to 13.4. I was told that they did not drive it over 65mph and that they had to drive it for five minutes to the left and five minutes to the right to get the clutch packs to seat. I was also told that the DIC readings would be off since they disconnected the battery to change the OnStar antenna. They accounted for the lower gas mileage saying that they left the car idling while they changed the OnStar antenna.
Truth or Bull?
Plus I was a little suspect when the service order writer did not know how to find and log the miles; therefore he listed it as 16,000 when I actually had 14,481 when I took it in.
Old Sep 25, 2006 | 08:59 AM
ProfMoriarty's Avatar
ProfMoriarty
IMO, they hammered the hell out of your car.
Remember the parking garage scene from "Ferris Bueller's Day Off"?
Old Sep 25, 2006 | 09:01 AM
stabori's Avatar
stabori
St. Jude Donor '08
I wouldn't worry, these guys don't get paid for driving around. And they even get paid less for waranty work. letting it idle will change the average fuel especially if you don't have many miles on it since you last reset it. They should have driven it a bit in slow 8s to break in the packs.
Old Sep 25, 2006 | 09:07 AM
juiceman03070's Avatar
juiceman03070
St. Jude Donor '08
The most important question should be are you happy with the repair..??? if so the rest is a wash.....IMHO
Old Sep 25, 2006 | 09:19 AM
Atomic Punk's Avatar
Atomic Punk
if it's fixed, count your blessings.
Old Sep 25, 2006 | 09:33 AM
Tom/99's Avatar
Tom/99
They may have let it idle for quite a while.
Old Sep 25, 2006 | 10:16 AM
ajsjr's Avatar
ajsjr
Good point . . . on the counting my blessings. I try to keep reminding myself that it is still just a car . . . but what a car! Anyway thanks for the 'reminder'
Old Sep 25, 2006 | 10:36 AM
Whiterock1's Avatar
Whiterock1
Truth or Bull?
If everything else was true, how the hell could the oil life go down that much in 15 miles? I can't even imagine anything but 60 passes at a drag strip!
Old Sep 25, 2006 | 11:02 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
If you let it just sit and idle, the oil life would eventually go to 0 with no miles added.
Ford says that for engine wear (not oil life), each hour of idling is equal to driving 33 miles. So if you want to see how much engine wear is on a used police car, take the odometer reading and double it.
Old Sep 25, 2006 | 12:28 PM
Whiterock1's Avatar
Whiterock1
5% oil life is roughly 400 miles. They drove it 15. How much idling would it take to make the equivilent of 385 miles, I wonder? Logically you would be talking about several hours--or a very hard 15 miles.
Old Sep 25, 2006 | 12:42 PM
gauSSian's Avatar
gauSSian
look in your rear wheel wells for telltale signs of burnouts.
recently read a thread where a Z06 owner discovered such signs in his wells.
Old Sep 25, 2006 | 07:10 PM
mbonness's Avatar
mbonness
When I got my car back from the dealer auto body it had the same mileage but it looked like they had let it idle quite a bit too (they were probably listening to tunes on my MP3 CD while it was sitting there in the paint shop since I noticed it was a lot further down in the playlist). Since I burned a lot of gas in the loaner car I would say everything evened out though.
So I'm inclined to say you should believe them and they were telling the truth since the alternative is too horrific to consider, i.e. breaking in new clutch plates by doing burnouts in the parking lot sounds like the worst possible scenario I can imagine.
Old Sep 25, 2006 | 08:30 PM
NFexec's Avatar
NFexec
Not long ago, a local owner of a brand-new Porsche 911 took his car to a nationally known tire store to get a different set of tires installed. He returned after work to discover the "technician" took is car out for a joy ride on the highway and totalled the thing. The dealer was sued for a replacement plus emotional damages. The "technician" is now asking if you want fries with that.
You just never know
Doug
Old Sep 25, 2006 | 08:39 PM
TN 2005 C6's Avatar
TN 2005 C6
Cruise-In VI, VII & XII Veteran
St Jude Donor '07-'08-'09
If you had the window valet installed you could check and see what the highest RPM and fastest speed recorded on your car and have the peice of mind you are seeking. But, on the other hand you might find out just how hard your car was driven. If all is well with the repairs do you really want to know?
Old Sep 25, 2006 | 08:59 PM
C5pilot's Avatar
C5pilot
Oil life is measured by revolutions (engine hours or hobbs) AND engine temp. There is no correlation between that and miles, period. It's in the manual.
I'd be more concerned about the service writer making up numbers because he/she is too lazy to find out how to read the odometer. That info is routinely turned in to reporting agencies and used to find odometer roll-backs. Carfax could send up a red flag if he gets another service or inspection before he reaches 16k miles, and it could be there forever because nobody will know how to fix it.
Old Sep 26, 2006 | 11:08 AM
Whiterock1's Avatar
Whiterock1
I said the equivalent of 485 miles. While miles per se may not be the determinent factor, equivalency of time idling vs time driving can be established. The reasonable man would conclude idling at 800 rpm vs driving at 1800 rpm would require a much longer time to reduce oil life proportionately.
Old Sep 26, 2006 | 11:19 AM
Gearhead Jim
St. Jude Donor '13
Probably true, but I've heard that the program in the OLI is pretty sophisticated- perhaps idling is interperted (correctly) as using up oil life more quickly than moderate driving. ???
To What would you think?
Old Sep 26, 2006 | 11:23 AM
djfullshred's Avatar
djfullshred
If it was me, and the car came back with a good repair & in as good a shape as I sent it off I wouldn't trip.
The Chevy dealer I go to always logs the odometer when you drop it off, so you know exactly how many miles they put on it. They get a lot of Corvettes there, so I have no suspicion they would take mine (which is just another one on the list) out for a joyride.
Old Sep 26, 2006 | 11:25 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
I used to live in a area that had 3 large dealerships close by on the main road. I saw a lot of their test rides. The old saying "Drive it like you stole it comes to mind"
Old Sep 26, 2006 | 12:06 PM
dmawd's Avatar
dmawd
Seems reasonable except for the avg mpg. Think the car was probably driven hard to cause change like that. You could disconnect the bat yourself and see waht the DIC readings are after you reconnect. I would think that either the info is stored in non volatile mem thus would not be lost or would display zero or ? or similar. Don't believe it would just put up random or erroneous readings like he told you.
