? on battery
Old Sep 25, 2006 | 04:12 PM
platinumkid's Avatar
platinumkid
Default ? on battery
is the dealer going to give me hell if i change the battery? i was waiting on the phone for 20 minutes for someone to help me and i said forget it!!! so i went and bought another battery and swapped it!! now my window doesnt wanna go up when i close the door! so i gotta go to the dealer tomorrow! what do you guys think?
Old Sep 25, 2006 | 04:19 PM
hyperjoe's Avatar
hyperjoe
If you are talking about the indexing feature, there is a procedure on how to reset that. Try searching for it.
Cheers!
Old Sep 25, 2006 | 04:29 PM
johnodrake's Avatar
johnodrake
Moderator
Window Indexing
This feature automatically lowers the window a small
amount when the door is opened. Then, when the door
is closed, the window will raise to its full up position.
If either window does not index properly, it could be due
to loss of power.
Before returning to your dealer for
service, perform the power window initialize procedure
following.
Power Window Initialize
After a power reconnect such as battery replacement, the
window index-up feature will not function until the system
is initialized. Once power is restored, do the following:
1. Close the door.
2. Raise the window by pulling up the switch.
3. Hold the up switch for three seconds after the
window is closed. Release the switch.
4. Hold the up switch again for three seconds and
release.
Owners Manual page 2-18
Old Sep 25, 2006 | 04:48 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Originally Posted by johnodrake
Window Indexing
to loss of power.
following.
1. Close the door.
release.
TO ADD TO THIS. If you want to save your mirror & seat settings (05 6spd M, possibly others) push the seat button to move all into place
then push the button again. Ebrake must be on.
Old Sep 25, 2006 | 05:25 PM
platinumkid
didnt know about this!! thanks alot guys!!! saved me a full day at the dealer!!!
To ? on battery
