C6 Differential Problems
Old Sep 25, 2006 | 09:02 PM
RASINC's Avatar
RASINC
7th Gear
Default C6 Differential Problems
I had a noise I thought in the differential. The dealer said they have had some problems with the synthetic fluid and have changed to the old fluid with the additive. They drained the fluid and found metal. Has anyone else had similar problems?
Old Sep 25, 2006 | 09:28 PM
greta's Avatar
greta
lots of previous posts on this. seems to be pretty common. after they flush it and fill it it seems to take care of the problem. at least it has for me up to now. grinding noise is all gone!
Old Sep 25, 2006 | 09:34 PM
Larry B.'s Avatar
Larry B.
Mine made a little noise and kinda felt rough at low speed making a tight turn. I added a 4 oz. bottle of Amsoil additive and drove in figure 8's. Now it is very quiet and smooth. Cost me $10.00 and took ten minutes.
Old Sep 25, 2006 | 10:03 PM
xlr8rvette's Avatar
xlr8rvette
From: Fayetteville Arkansas recently moved from Oakland Ca
St. Jude Donor '06
Lots of posts. Warranty item with final fix being for GM to replace the rear differential clutch packs. Again coverred by warranty
Old Sep 25, 2006 | 10:48 PM
mbonness's Avatar
mbonness
Yeah only about 142 of us have had this problem so far (including you now we're up to 143).
http://forums.corvetteforum.com/show....php?t=1497590
BTW the metal is from manufacturing imperfections, it's normal that you would see this the first time you drain the fluid...
To C6 Differential Problems
