Dbs Again !!!
Old Sep 26, 2006 | 05:15 PM
oldman's Avatar
oldman
Default Dbs Again !!!
Car set for two days. When I tried to get in the doors would not open. Had to go in through the trunk. The steering wheel was locked and in reverse with e-brake on. Measured the battery volts and it was 4.8 volts. Put on charge for three hours and it finally started. I called the dealer and made an appointment to install the new software. This is the fourth time this has happened in the last year and a half. The car is a 2005 with a manual trany. I have taken the car in to the dealer twice in the past and got the save answer (no problem found). I hope the new software will fix the problem. I will report to the form if this happens again after the software upgrade.
Old Sep 26, 2006 | 07:37 PM
VET4LES's Avatar
VET4LES
You will be a good test case since it's happened four times, let us know.
I hope you meant that you opened the door from the trunk and did not climb through it.
