New NAV Disk
Old Oct 2, 2006 | 09:01 PM
c2c4c6's Avatar
c2c4c6
Default New NAV Disk
Does anyone know the GM part number for the new Nav Disk (Version 3.0) for the 2005 NAV System?
Old Oct 2, 2006 | 09:11 PM
nuvetteowner's Avatar
nuvetteowner
Yes it is #15932106
Old Oct 2, 2006 | 09:16 PM
c2c4c6's Avatar
c2c4c6
Thanks. That one works in a 2005 system? I am not sure if the 2007 nav system is the same as the 2005.
Old Oct 3, 2006 | 04:44 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
If the '05 NAV has had the softeware update, then it will be the same as the '07 NAV. Even if it doesen't have the update, it will still be able to use the newer versions of the map disk. The software update was for the audio functions.
Old Oct 3, 2006 | 06:38 AM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
Originally Posted by nuvetteowner
Yes it is #15932106
That's the part # for 2007 Corvettes that came with the Version 3.0 Nav disc. The update disc from the GM Navigation Center has a small u at the end of that same part number.
Frank
Old Oct 3, 2006 | 11:44 AM
c2c4c6's Avatar
c2c4c6
Frank
But is it the same data on both?
Old Oct 3, 2006 | 01:35 PM
wwbill617's Avatar
wwbill617
I just picked my car up yesterday and the Navigation is not that good. My Garmin StreetPilot that is at least a year old has my home street on it. The new one in the vette does not. What is the latest disc? Maybe they gave me an old one.
Bill
Old Oct 3, 2006 | 01:48 PM
cgurley's Avatar
cgurley
Bill
My '07 that I picked up over the weekend has version 3. I believe this is the latest version. Much more up to date than my '05.
Old Oct 3, 2006 | 03:47 PM
c2c4c6's Avatar
c2c4c6
Will that new version work in your 05?
Old Oct 3, 2006 | 04:31 PM
wwbill617's Avatar
wwbill617
Just called gmnavdisc and the newest version available is part #15932106.
Old Oct 3, 2006 | 05:21 PM
cgurley's Avatar
cgurley
I sold my 05 to buy the 07.
Old Oct 3, 2006 | 11:44 PM
Radical05's Avatar
Radical05
Default wow
That was a pretty expensive nav disk buy. They are only $200 but I guess a trade was the way to go. There are plenty of other ways to get a V3.0 for under $10.
Old Oct 3, 2006 | 11:46 PM
Radical05's Avatar
Radical05
Default They all work
Yes every Nav disk works in the 05 and yes the all equally suck. Dont waste $200 if you are an 05 owner getting one cause you wont see that when you pop it in.
To New NAV Disk
