Caliper Paint
Old Oct 3, 2006 | 04:43 PM
tloon's Avatar
tloon
Default Caliper Paint
Has anyone had any experience with the non powdercoat, do it yourself caliper paint? I know there are products out there by G2 and Duplicolor. Looking for feedback.
Old Oct 3, 2006 | 04:54 PM
ohfiver's Avatar
ohfiver
Pior post suggest just useing regular spray paint with a primer. They reported no problems with non track cars.
Old Oct 3, 2006 | 05:03 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
I used Sunset Red Rustoleum brush on on my C5.. Stayed on for 5 years..
Old Oct 3, 2006 | 05:07 PM
Zymurgy's Avatar
Zymurgy
Moderator
Originally Posted by ohfiver
Prior post suggest just using regular spray paint with a primer. They reported no problems with non track cars.
Here is my DIY thread.
Old Oct 3, 2006 | 05:09 PM
Guitarstar's Avatar
Guitarstar
Primer, DupliColor Metal Cast Candy Blue 3 coats. DONE!
For Powder coating Corvettepilot- Mike is #1
Old Oct 3, 2006 | 05:11 PM
dashotgun's Avatar
dashotgun
i have used spary on vht paint for autozone on my previous car you need to mask it and spray it on a bit messy but durable as it is an epoxy system and good to 1500 degrees. On the vette I used the duplicolor system you paint it on it is a kit with masking tape brake fluid cleaner and paint and comes in various colors. The paint brush they supply sucks. I used a paint brush from lowes and it came out great the finish is not as nice as the powder coat but who cares it is a brake not the car. The system costs about 30 bucks compared to 100 for powder coating plus the time or expense of having someone else pull your brakes off and reinstall them. I would go with the duplicolor it is an expoxy and therefore more heat tolerent and durable. paint over the raised letters in the front and get a straight razor when done and shave the paint off I don't have apicture but if you go to http://81x.com/bugman/c6 and check out calipers it has a diy
Old Oct 3, 2006 | 05:19 PM
Mr. Wonderful's Avatar
Mr. Wonderful
From: Slower than a speeding bullet................ Fort Lauderdale, FL
I painted the calipers on my old '02 with Rustoleum Sunset Red.
A quart cost about $8. If you can find it in a pint can that's more than enough.
Paint it on with a brush and it will look great.
Be sure the calipers are clean first. If not, spray with a brake cleaner and wipe clean.
No need for powdercoating.
Old Oct 3, 2006 | 05:20 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Go to search and put in "painting brake calipers" and you will find the thread that I started on 9-23-06.
Old Oct 3, 2006 | 05:49 PM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
I used the Duplicolor kit. It worked great. The key to it (if you use it) is to get a few GOOD brushes used for painting ceramics from an art or hobby store. Get a 3/4 or 1" and a small flat 1/4" to go in between the letters. When you're done, scrape any paint off the letter (or use some chapstick on them so paint does not stick).
I was able to do all four with 3 coats in about 2 hours. Id post some pics buty my son is away with my camera.
Old Oct 3, 2006 | 06:37 PM
RaceMic's Avatar
RaceMic
Just "G2d" my C6 calipers over the weekend. I used the same 2 stage epoxy on my C5 several years ago and the paint held up perfectly.
Old Oct 3, 2006 | 07:06 PM
V Vette's Avatar
V Vette
Walmart exterior spray paint at $2.99 a can... Dont waste your money on "Caliper paint"....
Old Oct 3, 2006 | 07:25 PM
tloon's Avatar
tloon
Thanks guys, excellent feedback. A good winter project for me.
Old Oct 3, 2006 | 09:40 PM
BlueSpeed's Avatar
BlueSpeed
I've used G2 in the past and really like the shiny finish, brushes on easily too,
do the spray paints have the same glossy finish as the G2?
Old Oct 3, 2006 | 09:52 PM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
Duplicolor brush on $9.99 pepboys
Old Oct 4, 2006 | 02:38 PM
docrings1's Avatar
docrings1
C6 FAQ Master
Check the FAQ for a DIY series on this topic...
http://forums.corvetteforum.com/show...post1548560567
Painting Brake Calipers:
http://forums.corvetteforum.com/showthread.php?t=923043
Cheers!
Doc
To Caliper Paint
