I am going to have my brake calipers powder coated and I was wondering is there any sequence to bleeding the brake on the install, and has any one run into any problems?
It also gives a procedure for bleeding the master cylinder before the calipers if the master cylinder got air into it. May be best to avoid that by figuring out a way to plug the lines while the calipers are off, and not run the M/C dry. Maybe golf tees and duct tape? If you leave the cap on the M/C not too much will run out while disconnecting, then try to get a tee in there quick.
To avoid air in lines, top off mc after each caliper swap...it is manageable, and will save you tons of extra work.
