DIC Volume Adjustment
Old Oct 29, 2006 | 01:18 AM
10mikeymike's Avatar
10mikeymike
Default DIC Volume Adjustment
This question may have been asked before, but I did a search and couldn't find anything. Is there any way to adjust the DIC volume? I find the beep too loud when pressing any of the DIC or HUD buttons.
10mm
Old Oct 29, 2006 | 03:05 AM
shopdog's Avatar
shopdog
10mm
There are only two settings, loud and louder, in cars without Nav. In cars with Nav, there is only loud.
Old Oct 29, 2006 | 05:17 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Old Oct 29, 2006 | 05:58 AM
10mikeymike
Yeah, so I've learned. I found the section on chime adjustment after I posted this thread. Thanks!
10mm
Old Oct 29, 2006 | 11:38 AM
C6SNOOPY's Avatar
C6SNOOPY
Question from above: "This question may have been asked before, but I did a search and couldn't find anything. Is there any way to adjust the DIC volume? I find the beep too loud when pressing any of the DIC or HUD buttons."
I don't get a chime sound when I press any of the HUD buttons on the left side. I only get chime sound on the buttons pressed on the Right side. Does anyone else get silent pressing of the left side?
No way to adjust that I have found.
I assume this is the normal situation?
Old Oct 29, 2006 | 12:22 PM
Vette_DD's Avatar
Vette_DD
You're right, it's normal. No chime when pushing the buttons on the left side of the HUD.
Old Oct 29, 2006 | 05:13 PM
slomarsh's Avatar
slomarsh
Default Thanks for the DIC volumn info. It helped.
A timely post. I thought the tone on the DIC was too loud, too. Thanks to this thread, followed the directions by holding selector button #6. Turns out it was set on "loud". Changed it to "normal". It is better now.
Old Oct 30, 2006 | 08:51 AM
6 speed Sid's Avatar
6 speed Sid
What selector buttom #-6 ??
Old Oct 30, 2006 | 09:33 AM
AFVETTE's Avatar
AFVETTE
Tom
Old Oct 30, 2006 | 12:26 PM
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
Old Oct 30, 2006 | 12:27 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Old Oct 30, 2006 | 04:00 PM
Vette_DD's Avatar
Vette_DD
Radio preset button no. 6. 2006 owner's manual, page 3-101.
Note: this info. does not seem to be in the 2007 owner's manual.
Chime Level Adjustment
The radio is used to adjust the vehicle’s chime level.
To change the volume level of the chime, press and hold
pushbutton 6 with the ignition on and the radio power
off. The volume level will change from the normal
level to loud, and LOUD will appear on the radio display.
To change back to the default or normal setting,
press and hold pushbutton 6 again. The volume level
will change from the loud level to normal, and NORMAL
will appear on the radio display. Only one chime will
be heard when changing from the normal to the
loud setting. Each time the chime volume is changed,
three chimes will sound as an example of the new
volume selected. Removing the radio and not replacing
it with a factory radio or chime module will disable
vehicle chimes.
Old Oct 30, 2006 | 06:17 PM
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
That is for the alert chimes, not the DIC sound "*****"
Old Oct 30, 2006 | 06:54 PM
Vette_DD's Avatar
Vette_DD
I thought they were the same. When my radio sound went out, I had neither chimes nor DIC "*****." I have not actually changed the volume of my chimes, so I really couldn't say.
EDIT: I just tried it and your statement is incorrect. It is for both.
Old Oct 30, 2006 | 07:07 PM
Scruff Vette's Avatar
Scruff Vette
Thank you for the post I just tried it and it does indeed work
Old Oct 30, 2006 | 07:15 PM
beaversstonehaven's Avatar
beaversstonehaven
I'm heading to the garage right NOW! I sure hope it has been on the loud setting.
Old Oct 30, 2006 | 07:41 PM
MichaelB's Avatar
MichaelB
St. Jude Donor '06
vehicle chimes.
This needs to be in the FAQ section Thanks
To DIC Volume Adjustment
Old Oct 30, 2006 | 08:48 PM
6 speed Sid
Very good info. I have looked, but never saw this.
Old Oct 30, 2006 | 08:58 PM
beaversstonehaven
Dog gone it.....it was on the normal setting.
Old Oct 31, 2006 | 08:23 AM
docrings1's Avatar
docrings1
C6 FAQ Master
In the FAQ! Good link!
