Winter storage
Old Nov 1, 2006 | 06:28 AM
lanczar's Avatar
lanczar
Default Winter storage
The long Minnesota winter will be here soon and I am faced with storing my "little white car" in my UNHEATED garage until the snow and "SALT" are a memory.
In talking to folks about storing a car, I get conflicting opinions. I bought a good quality cover, but do I:
Do I disconnect the battery? (Most think YES)
Do I not start the car all winter? (Causes engine condensation)
Do I put the car on jack stands? (50/50)
Do I remove the tires?
I would like to hear from other Corvette owners who live in cold weather states.
Old Nov 1, 2006 | 06:35 AM
shortski's Avatar
shortski
Take the battery out, store in a cool dry place, do not place directly on a concrete floor, card board box on top of a piece foam board insulation is ideal. Bring to full charge before storing and before returning to service.
Hard to start with no battery.
Tire care, inflate to maximum pressure on sidewall, will help to prevent flat spotting, shouldn't be a problem if storage is for 6 months or less/
Before putting to bed, change oil and put fuel stabilizer into a full tank of gas, helps prevent condensation.
I've stored mine in Vermont this way with no problems.
Old Nov 1, 2006 | 07:24 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Do a search on this subject. This is a topic that comes up often. There are a lot of threads out there.
Old Nov 1, 2006 | 07:39 AM
legalgus's Avatar
legalgus
Considering the amount of money you have in the car, I would recommend private, dry & heated storage. Take out the battery, put some dry gel packets (marine stores sell this stuff) in the car and for 5-6 months you should be o.k..
Old Nov 1, 2006 | 07:44 AM
BobILoveAVette's Avatar
BobILoveAVette
I have stored corvettes for over 30 years. Prior to all the electronics starting with the c4, I would just start every other week and take a run around the block. With the C5s and c6s, a battery tender is a must as I do not disconnect the battery. If you do, take off both cables. I have had no (zero) side effect with leaving the car and tires on the ground, no flat spots, no nothing.
So, it is what ever makes you comfortable. I just chose to keep a battery tender on it and that's it. A warm winter day and the car is ready to roll to take advantage of the weather.
Old Nov 1, 2006 | 08:39 AM
JVM225's Avatar
JVM225
St. Jude Donor '06
I've used a Battery Tender Plus for years now with no problems.
I also inflate the tires to a few pounds over, top off the tank and add Stabil, but I don't start the car until the spring.
Old Nov 1, 2006 | 09:27 AM
FlyinLow's Avatar
FlyinLow
I'm in Minnesota and our winters are pretty dry. I use a battery tender on the Vette and both of my bikes and leave the batteries in them. Change the oil, put in Stabil, inflate the tires up and cover the car with a breathable cover. Some other tips are to use a good rubber conditioner on your weatherstripping as well as a leather conditioner on the interior. If you are storing in an area where mice are an issue, cover the exhaust tips with empty pop cans (cut one end off) and you will need to use something in the interior to keep them out. I've heard people recommend Bounce dryer sheets, but have also heard from people that this is not effective either.
Old Nov 1, 2006 | 10:29 AM
johnodrake's Avatar
johnodrake
Moderator
Ditto here.
Old Nov 1, 2006 | 10:54 AM
SpdWhite's Avatar
SpdWhite
Ditto. The only other thing I do is fill the tank, add stabilizer and take it for a ride to make sure the stabil is everywhere. In the spring one of the first things I do is change the oil.
Old Nov 1, 2006 | 10:58 AM
ProfMoriarty's Avatar
ProfMoriarty
For my garaged C6:
1. Fill gas tank and add Sta-Bil (7.5 oz.); run through fuel lines.
2. Change oil and filter.
3. Park on moisture barrier
4. Inflate tires to 38 psi cold.
5. Apply sealant, wax, etc. to exterior paint.
6. Apply leather dressing to seat panel.
7. Apply vinyl dressing to interior; and to exterior black trim pieces.
8. Hook up Batter Tender. Run wire into engine compartment from underneath car and duct tape exposed wire to floor so you don't trip over it and yank it out.
9. Crack windows a bit.
10. Cover with Wolf Dustop inside car cover.
11. Wait for Spring.
Old Nov 1, 2006 | 11:20 AM
2008corvette's Avatar
2008corvette
I also live in Minnesota. Heres what I just did yesterday.
- Filled gas full tank on my way home.
- Spent 3 hours cleaning entire car.
- Add Sta-Bil to gas tank
- Put about 30 sheets of "Bounce" dryer filters inside the car (keeps the mice out)
- Drove my C6 down to our Pull-barn and parked it on my Car Capsule mat.
- Hooked up my battery tender.
- Put my car cover on.
- Zipped up my car capsule and inflated it for the long winter.
- Went inside and ordered some new mods for the spring, Pipedreams chrome engine caps and a etched fuse box cover.
Old Nov 1, 2006 | 11:27 AM
ProfMoriarty
If your car is in a bubble why would you need to cover it or put dryer sheets inside the car to keep mice out?
Old Nov 1, 2006 | 11:34 AM
2008corvette
I put a car cover on to protect the paint finish. When you zip the capsule up, the plastic has to rest on the car until it inflats. In case the bubble delated for some reason, I don't want the plastic to scratch my car. Mice could actually still get inside the bubble where the fan blows the air in, I used Bounce sheets just in case. This will be my third year with my car capsule, first time for the my C6.
To Winter storage
