CCW C6 Wheels
Old Nov 1, 2006 | 10:10 AM
chuckclanton's Avatar
chuckclanton
Default CCW C6 Wheels
I just found out from Chip that CCW now has better fitting wheels
for the C6. 18x9.5 57mm offset in front(275/35/18) and 19x11 79 mm
offset(325/30/19). He says no rubbing on inside rear and flush fit on
outside.
Old Nov 1, 2006 | 04:40 PM
Monterrey Bill's Avatar
Monterrey Bill
St. Jude Donor '03-'04-'05-'06-'07-'08-'09
outside.
Is this the SP 500 you are talking about?
Old Nov 1, 2006 | 05:19 PM
chuckclanton
Default Which?
Chip said all styles except one, which I don't recall which.
Old Nov 1, 2006 | 05:40 PM
AP's Avatar
AP
Old Nov 1, 2006 | 05:55 PM
Gene Gorman's Avatar
Gene Gorman
I have 505s in that size. I think they were the first set they made and put on a c6. John personaly put them on and took a bunch of pictures of the wheels on my car. The offset is the same as the stock wheels, but they are 1" wider front and back. The lip of the wheel moves to the outside of the car by1/2". By moving out 1/2" they line up perfectly with the fender. You can use the stock size tires with these wheels. Ask John or Chip to post some pictures of my car with these wheels . They look great. John and Chip are realy nice guys to work with. If you want to see it I will be at the Turkey Rod Run in Daytona this month, if the car gets back from NLP for it's cam and mp122, otherwise will have to take the 67.
Old Nov 1, 2006 | 09:06 PM
Monterrey Bill
I have been looking at a lot of different wheels trying to decide which ones I want to buy, and really like the SP 500 series they have.
Wish there were more choices that fit the C6.
Old Nov 2, 2006 | 10:30 PM
Lexicon's Avatar
Lexicon
That is a perfect offset for the 18x9. That gives another .5 inch clearnace for calipers. Will the ZO6 calipers work?
To CCW C6 Wheels
