Do I need jacking/lifting pads?
Old Nov 1, 2006 | 07:00 PM
Gumdoc's Avatar
Gumdoc
Default Do I need jacking/lifting pads?
I hope to be installing my new GHL exhaust system this weekend, and I will be doing it at my local military (Air Force Academy) auto craft shop. They have regular commercial-grade car lifts and I don't know if I will need rubber jacking/lifting pads or if I just need to be careful where I put the ends of the lifts on the frame. My owner's manual shows where to put a jack, but I don't know if I will need the additional protection of pads. I have a friend who has pads for his C5, and I am guessing they will probably work. Advice?
Old Nov 1, 2006 | 07:08 PM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
You may not need pucks depending on the type of lift. Some lifts I've seen, at tire shops for example, lift the car by the rocker panels, and for those you need pucks. If the lift has adjustable arms and lift points an inch or two higher than the arm, just position the lift points at the car's jacking points and be careful not to touch or put pressure on the painted rocker panels. Any pucks will work if you need them at all, even hockey pucks.
Old Nov 1, 2006 | 07:28 PM
06LS2's Avatar
06LS2
Just went into the dealer for the first time this week for the roof fix recall and rear end noise TSB. Before I knew it car was up on the lift without jack pucks that I had in the car. I was beside myself. Lo and behold, the body flexed. Had a quarter inch gap on the drivers side door and front fender. Discovered this after the car was home.
Lesson learned: If you have jack pucks with you, make sure you tell the Tech or person you have them and use them......
Old Nov 1, 2006 | 07:31 PM
timd38's Avatar
timd38
Just go to the BMW dealer and buy a set of theirs for $15.00 and just leave them in like they are should be.
Old Nov 1, 2006 | 07:47 PM
trader11's Avatar
trader11
i agree with the suggestion for the bmw pucks. they have saved my z06 more than once.
Old Nov 1, 2006 | 09:50 PM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
If the Tech had any brains, he wouldn't lift a Corvette without them.
Old Nov 1, 2006 | 09:52 PM
ProfMoriarty's Avatar
ProfMoriarty
Better yet install the higher BMW rectangular pads, leave them in, and walk the shop manager and tech over to your car and point the pads out to them.
Old Nov 1, 2006 | 10:38 PM
gordonboss's Avatar
gordonboss
Default Pucks
new guy 1st vett. How you do that. Not buy them, put them in?
Old Nov 1, 2006 | 10:39 PM
ProfMoriarty
They snap in.
This is a shot of the side that bears aginst the frame rail. The ears snap into the frame rail shipping slots. The rectangular ones, in addition to being taller, have a perimeter gasket and retaining pin.
(Damn, I resized the pic and it's still huge. Sorry 'bout that.)
Old Nov 1, 2006 | 10:59 PM
gordonboss's Avatar
gordonboss
Default puck install
thank you very much. Off to the beemer dealer tomorrow. Had one of those once and swore I would never go there again. Oh well, it is for a proper cause. Thanks again for the help. Pic is just fine.
Old Nov 1, 2006 | 11:04 PM
ProfMoriarty
Any time!
Enjoy your new ride!
Old Nov 1, 2006 | 11:34 PM
Gumdoc's Avatar
Gumdoc
Thanks for all the good answers, guys. I may be off to the Beemer shop myself.
Old Nov 2, 2006 | 12:03 AM
Daniel Redfoot's Avatar
Daniel Redfoot
Default Pucks
Do a quick Search. Some Forum member made a set out of Hockey Pucks and screw-eyes. Absolutely Brilliant and inexpensive solution
Old Nov 2, 2006 | 01:42 AM
Vasta's Avatar
Vasta
St. Jude Donor '06-'07-'08-'09-'10-'11-12-'13-'14-'15-'16
You need to have a serious talk with the Service Manager at your Dealership about this. They know all about puck's going under Vette's before lifting. Any damage to your car is there responsibility.
Old Nov 2, 2006 | 03:11 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
If you get the jacking pucks from Elite Engineering do not leave them mounted on the frame rails, they can come off unexpectedly. The good news is that you can buy singles for replacements.
Old Nov 2, 2006 | 11:21 AM
06LS2's Avatar
06LS2
You bet I did!!! I had his full attention in his office. To his credit though he was new to Chev dealership. He said he would talk with his Techs and also consider buying a new lift for the service bay. I did feel better venting afterwards. Most important, no damage to the underside and the body flexed back to the original gaps as far as I can determine....
Old Nov 2, 2006 | 11:30 AM
shortski's Avatar
shortski
If the Beemer dealer is out of stock don't put off the install, you're gonna love the sound of the GLH system, go to Wallmart and pick up four hockey pucks to use in the interim, just put them between the frame rail and the lift.
Old Nov 2, 2006 | 11:42 AM
gordonboss's Avatar
gordonboss
Default got the Beemer Pucks
Originally Posted by ProfMoriarty
They snap in.
Went down to Beemer store, Guy said you SURE you want these for a Corvette? They won't work!
$12.50 each (thick ones) fit like a glove and the retaining pin looks like it should hold them real tight. Nice insurance policy!!!!
Thanks again ProfMoriarty.
To Do I need jacking/lifting pads?
