Fuel door problem
Old Nov 6, 2006 | 08:30 PM
tsjolly's Avatar
tsjolly
Default Fuel door problem
My Vette is an 05 1sb z51 A4. All of a sudden everytime I release the fuel door to fill up the car with gas I can't shut the door. I have to open the trunk, peel back the carpeting, and manually return the "manual fuel door release handle" with my fingers. And other times it just opens while I'm driving. Very embarassing, considering what I'm driving. Does anyone have a quickfix for this problem?
Old Nov 6, 2006 | 09:42 PM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
After 8k and 1.5 years mine started with the same problem. I found if you press the release button again it pops out. Sprayed a small amount of wd40 and now it appears fine.
Old Nov 7, 2006 | 12:57 AM
LMB 4 ME's Avatar
LMB 4 ME
From: Boca Raton Inlet, Atlantic Ocean (Floridas east coast)
Exactly, plus make sure the "pull handle" in the trunk has a tad of slack in it.
Old Nov 7, 2006 | 01:47 AM
shopdog's Avatar
shopdog
Grind one edge of a nickel so it is straight across (a chord of its diameter) and beveled at a 45 degree angle. Glue or screw the nickel to the latch tongue on the fuel door. What this does is extend the edge of the catch about 1/16th of an inch toward the lock plunger. It'll now latch and stay closed. I did this a year and a half ago when mine started doing what yours is doing. It has worked fine ever since.
To Fuel door problem
