Does anyone's seat move when you open the door?
![](/forums/images/ranks/1k-2k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_air_force.png)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
About one in twenty times I go out to my car, I find the seat moves back to the "exit" position as I open the door. I almost always use the same set of keys so I don't think it has something to do with different settings. Anyone have an idea why this happens sometimes?
![](/forums/images/ranks/11k.gif)
I've not ever had that to happen. I'd make sure I had both fobs programmed the same. I've programmed both of mine the same, although I always use fob no. 1.
![](https://www.corvetteforum.com/forums/images/ranks/veteran_marine_corp.png)
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
![](https://www.corvetteforum.com/forums/images/ranks/stjude15.jpg)
This sounds like a job for
![](http://i48.photobucket.com/albums/f217/msammet/Ghostbusters_Ringer-T-link.jpg)
![](/forums/images/ranks/100-500.gif)
Eddie
![](/forums/images/ranks/3k-4k.gif)
Location: Austin, Texas Codes 660, 9448, and 295660 work in the C6 navigation unit. No DVD playback yet.
Are you sure you're using the same "profile"? Maybe the two are set exactly the same except for the "exit seat recall" function? Maybe you've inadvertantly selected it while driving?
My wife and I have nearly identical settings, and it can be hard to tell we aren't driving your own profile if we aren't paying attention. One minor difference, I love the exit seat functionality while my wife hates it. Guess how we usually find out we're using the wrong profile?
I believe if you shut the car off AFTER you open the door, the seat does not move into the entry/exit position. Then the next time you open the door, the seat moves to the entry/exit spot. Or something like that. I think it has to do with the sequence in which you exit the car.
NCM Lifetime Member
Originally Posted by xlr8rvette
Maybe it's "seat slap" ![*****](https://www.corvetteforum.com/forums/images/smilies/willy_nilly.gif)
![ROFL](https://www.corvetteforum.com/forums/images/smilies/rofl.gif)
![](/forums/images/ranks/500-1000.gif)
Originally Posted by elofdahl
I'm not sure if you have the manual tranmission or not...but if you do, the exit seat reposition will only accuate with the park brake applied.
Eddie
Eddie
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
![](/forums/images/ranks/7k-10k.gif)
![](/forums/images/ranks/2k-3k.gif)
if you start the car with the door open sometimes, it puts a ghost in the machine, I had the same issue on my c5. I finally just turned off the exit feature on the settings( see owners manual)
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
I have the exit seat movement working when exiting but does the entry seat movement work on the manuals or just the automatics? I have never been able to get mine to go to my preset unless I hit the #1 button on the door. Or do you have to do that?
Moderator
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
Received 3,627 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
Mine is programmed to move every time. I have a Manual Trans and it will not move unless the hand brake is set.
Originally Posted by Hoonose
The poster is stating that the seat moves back on entry to the car...
