I would suggest you start by looking at the C6 FAQ Sticky at the top of the page of titles. Here's a link from that thread that might help. There may be others if you'll look through the FAQ.
I am a novice at this, I never messed with any car parts in my life so I need a little walking through here. The driver door is fairly different than the passenger door. Can anyone please help?
There is a plastic tab 3 inches long covering the Torx screws behind the door pull. Remove them, Then, with your fingertips pry off panel starting from the UPPER left side of door panel it should "peel" off
As mentioned, remove the tab.
The torx screws are exposed, remove them.
The button to open the door can be pulled out to facilitate diconnecting the wiring to the button.
Botton edge of panel is a slot to start a tool for prying panel off from the bottom up. Lots of noise, but no damage.
Lift up off window sill after everthing is loose from the bottom up.
Reverse to install.
I wish I could find a pic for you. When you're in the car and go to open the driver's door, you grab a handle on the door with your hand and push the button with your thumb. Behind that handle your hand is on is a small plastic, door-colored plate, perhaps 1/2" tall and 3" long. Pop that off and there are two torx screws behind it. Remove those. Then, look at the bottom of the door panel where it meets the door, get down on your back and look up. There are slots to start prying the bottom of the door panel off with a tool, use a padded screwdriver. Once you can get your fingers between the door panel and the door at the bottom pull out until the panel is just hinged along the top edge. Now lift it straight up and the panel will be free. Reach behind and disconnect wiring. Hope this helps. Will keep looking for a pic.
After reading the whole tread, it is obvious that you are not confident in taking apart the door panel. DON'T do it then. Isn't your car still under warranty? If so, then simply take it to the dealer.
