Misaligned door
Old Nov 8, 2006 | 01:22 AM
JRfigo's Avatar
JRfigo
Default Misaligned door
I know I read something about it several months ago, but after extensive search I couldn't find the threads.
I thought this problem was happening on the 05s, but I have an 06 and the door is not aligned correctly with the car, it goes it half an inch so the border on the car next to the door gets a lot more dirt and it's prone to get ruined quickly. How do I fix it?
Old Nov 8, 2006 | 01:25 AM
Stingray23's Avatar
Stingray23
My drivers side door does not line up that well either. It actually rubs with the fender everytime I open it. It get to a point now where there is some paint missing due to the rubbing.
Old Nov 8, 2006 | 02:04 AM
2LT-Z51's Avatar
2LT-Z51
i had to adjust mine too.....
this is how much i had to move it.... (scape marks next to bolt)
Old Nov 8, 2006 | 02:07 AM
2LT-Z51's Avatar
2LT-Z51
do you have a pic or drawing??
Old Nov 8, 2006 | 05:54 AM
Sven's Avatar
Sven
St. Jude Donor '08-'09
for details on this problem see Ed (Pipedreams) "paint saver bumpers" @ nakidparts ... great close-up fotos of the issue/resolution.
Old Nov 8, 2006 | 10:55 AM
shortski's Avatar
shortski
Got mine on in time, minor scratches buffed right out, thanks Ed
http://www.nakidparts.com/id14.html
Old Nov 8, 2006 | 05:20 PM
slomarsh's Avatar
slomarsh
Default Mis-alignment here too
If I understand correctly most of you have the problem where the door meets the front fender?
Mine is where the door meets the rear body panel/fender. The door sticks out too far. It is fully closed but does not appear to be. Front edge against front fender is fine.
Anyone else fixed a similiar problem?
I hate, repeat hate, to let a dealer do this because something else will be messed up in the process.
Old Nov 8, 2006 | 05:36 PM
shortski's Avatar
shortski
No, same problem you have, rear of door sits lower than rear quarter panel. Look at the pictures in my previous post, thats looking from the front to rear.
Old Nov 8, 2006 | 05:49 PM
Zymurgy's Avatar
Zymurgy
Moderator
No, slomarsh stated that his door sticks OUT too far, looking like it is not closed completely. This is exactly opposite the problem you describe.
In this case, Ed's fix is not the answer.
Old Nov 8, 2006 | 06:05 PM
shortski's Avatar
shortski
Not according to his original post. I taking that "it goes it half an inch so the border on the car next to the door gets a lot more dirt" to mean "it goes in half an inch so the border on the car next to the door gets a lot more dirt", I'm confused.
Hey JRfigo, is it the lower bottom of the door, when closed, that sits lower than the adjacent rear quarter panel, or is the door when closed sitting higher than the rear quarter panel??
Old Nov 8, 2006 | 06:20 PM
Zymurgy's Avatar
Zymurgy
Moderator
I think the confusion is that slomarsh was not the original poster. But you replied to him as if he had the door goes in too far problem.
OP (JRfigo) has the door goes in too far problem.
Old Nov 8, 2006 | 06:25 PM
not08crmanymore's Avatar
not08crmanymore
mine are all fine,on the other hand,but the gap between the dash and door on the passanger side is wider than it is on the driver side.
Old Nov 8, 2006 | 06:47 PM
shortski's Avatar
shortski
AHHHH, the dawn comes over Marblehead
Old Nov 8, 2006 | 06:50 PM
shortski's Avatar
shortski
Check at the bottom of the door. I believe GM put a bumper there to correct the alignment problem previously mentioned, check it to see if it's the problem. You may be able to shave it down to get it to align.
Good Luck
Old Nov 8, 2006 | 08:14 PM
Hoonose's Avatar
Hoonose
Check at the bottom of the door. I believe GM put a bumper there to correct the alignment problem previously mentioned, check it to see if it's the problem. You may be able to shave it down to get it to align. Good Luck
My own solution when the problem first came to light about 2 years ago:
http://forums.corvetteforum.com/phot...00/ppuser/6747
To Misaligned door
