valet window
Old Nov 8, 2006 | 12:14 PM
reptilneto's Avatar
reptilneto
Default valet window
Hi my valet window still dont work help please,
I plug the valet to my car I press the 3 times lock ,3 unlock and nothing happen,do I have to program this thing to make the windows go down or up??
Old Nov 8, 2006 | 12:22 PM
Dueysan's Avatar
Dueysan
The settings on your window valet may be slightly different. I know on mine I can press unlock twice and then lock to raise the windows. Try that first. My module was set up that way from the beginning. I think to lower them it's lock lock unlock......hmmm now I'm gonna go out and try it. You can change the settings to work in the manner you are doing it I believe....just a matter of changing the setting.
Old Nov 8, 2006 | 12:33 PM
Dueysan's Avatar
Dueysan
Ok just went out and tested mine. Unlock unlock lock will raise the lowered windows. Doing that code again will vent them. Unlock unlock unlock will lower them to where just the edge is showing, doing it again will lower them completely.
Old Nov 8, 2006 | 12:37 PM
reptilneto's Avatar
reptilneto
thank you but my question is do I plug and play or I have to program this thing??
Old Nov 8, 2006 | 02:10 PM
bbster's Avatar
bbster
It is plug and play....
Old Nov 8, 2006 | 02:32 PM
Dueysan's Avatar
Dueysan
Yep it is plug and play and then there are certain options you can program. Here is a link to some instructions offered by Elite Engineering.
Link!!
http://www.eliteengineeringusa.com/C6Window_Valet.html
To valet window
