Need help.....
Old Nov 9, 2006 | 07:22 PM
c6 rocket's Avatar
c6 rocket
Default Need help.....
Just removed my corvette logo door sill and after removal I have noticed alot of leftover adhesive. Any suggestions on how I can remove this without damaging the finish?
Thanks.
Old Nov 9, 2006 | 07:27 PM
dcress1127's Avatar
dcress1127
Thanks.
Goo Gone, WD 40, Polishing Compound all work pretty well mixed with a little elbow grease.
Old Nov 9, 2006 | 07:29 PM
c6 rocket's Avatar
c6 rocket
WD 40 will remove the adhesive?
Old Nov 9, 2006 | 07:37 PM
dcress1127's Avatar
dcress1127
I,ve used WD40 to remove a number of different type of adhesives,tar, tree sap and even mixed it with polishing compound to rub out a door scrape. This stuff is almost as valuable in the garage as duct tape.
Old Nov 9, 2006 | 07:43 PM
c6 rocket's Avatar
c6 rocket
Just tried WD40 and it did not work. Any other suggestions?
Old Nov 9, 2006 | 07:50 PM
06C6Z's Avatar
06C6Z
Amonnia, lighter fluid (careful).
Old Nov 9, 2006 | 07:52 PM
c6 rocket's Avatar
c6 rocket
Should I not be smoking or will it damage the paint?
Old Nov 9, 2006 | 08:28 PM
BBBOOMR's Avatar
BBBOOMR
Many detail shops use a product called Acrocyl to remove adhesives. It's not sold retail. Check with a cardealer's detail shop or parts dept. or try a body shop to buy a small quantity. Bring your own container.
Old Nov 9, 2006 | 08:30 PM
Big Lebowski's Avatar
Big Lebowski
Thanks.
Sandpaper.
Old Nov 9, 2006 | 08:41 PM
cthusker's Avatar
cthusker
... I used goo be gone but you gotta let that stuff set on there for awhile. Maybe 15 mins. After the adhesive got melted I then used a soft plastic squeegee to scrap it off. A old credit will also work. Keep wiping the squeegee with paper towel as the adhesive comes off. Make sure you clean the sill plate very well after your done so the new sill plate well.
Old Nov 9, 2006 | 09:11 PM
wayback's Avatar
wayback
MEK will remove the glue but please spot test it first. It will disolvr some paints and fiberglass resin. Our cars are plastic so I do not know....
Old Nov 9, 2006 | 09:17 PM
emejay's Avatar
emejay
This technique worked for me too.
Old Nov 9, 2006 | 10:32 PM
06C6Z's Avatar
06C6Z
lol...that my friend is totally up to you.
Old Nov 10, 2006 | 01:02 AM
LMB 4 ME's Avatar
LMB 4 ME
From: Boca Raton Inlet, Atlantic Ocean (Floridas east coast)
Originally Posted by Dlinderman
Sandpaper.
You gotta be carefull with jokes like that, some people may actually try it....O yea, thats on the MustangForum, sorry.
Old Nov 10, 2006 | 01:12 AM
LayItdown's Avatar
LayItdown
Bug and Tar remover by turtle wax. Simply wipe on wipe off gently.
Old Nov 10, 2006 | 07:41 AM
C8-Vette's Avatar
C8-Vette
Expensive kerosene,but it works without paint damage.
Old Nov 10, 2006 | 07:49 AM
c6 rocket's Avatar
c6 rocket
Sandpaper.
Ha, Ha. No way.
Old Nov 10, 2006 | 07:51 AM
c6 rocket's Avatar
c6 rocket
Just tried that. It removed the sticky but not the product. It seems like there is a thin membrane of adhesive tape.
To Need help.....
