Enclosed car trailer
Brand? Model? Size? Features?
Thanks for any information you can help me with.
This is a 20' by 8 1/2' wide x 6' 6" interior height. This is a smooth wall (no rivets) and includes a wall mount for the spare tire (some have under floor locations which means you need to remove the car to get to it), a full size Interstate battery to run the breakaway switch, 4 ceiling lights, 2 in-floor lights, and painted plywood floor (deck paint). I did not order the interior kit to keep the trailer lightweight - about 2900 lbs. (some are around 4,000 lbs. with all the plywood walls, etc.). I did order aluminum wheels. My ramps are hinged "anti-slip ladder style" and in addition to the door height, they extend easily to add another 9 feet, for a total ramp/door length of about 15 ft.
I have towed it with both 1/2 and 3/4 ton trucks, and recommend the 3/4 ton extended cab at a minimum... you don't even know it's back there... But of course, you need to do it right - get a weight distributing hitch and anti-sway controller....Low maintenance too - I just repack the wheel bearings every season and it runs forever !
I have hauled C3, C4, C5, and C6 Vettes and all fit perfectly.... I'm sure the older Vettes will also since this is built for low ground clearance vehicles already.
I have had this trailer for 6 years, and I love it. I highly recommend Triple B. Here are a few pics.
If you have any other questions, feel free to email me...
Bob
Bob
