when to shift to reverse?
Old Nov 17, 2006 | 03:27 AM
MIKLL's Avatar
MIKLL
Default when to shift to reverse?
my battery tender question brought up a new question for me....when should you shift to reverse?before you shut down the engine or after?i allways have waited till the DIC tells me to shift to reverse.does this matter?...thanks again..Mike
Old Nov 17, 2006 | 07:33 AM
C8-Vette's Avatar
C8-Vette
I shift to reverse first, than shut ignition. Not sure if it makes any difference, but this sequence has been suggested by Forum members in ths past.
Old Nov 17, 2006 | 07:38 AM
Hound's Avatar
Hound
I shift into reverse first and even let clutch out a little just to be sure it go's reverse. I always back my vette into the garage anyway and thats a great help because you know your in reverse !
Old Nov 17, 2006 | 07:43 AM
not08crmanymore's Avatar
not08crmanymore
Default reverse
I personally don't think it makes a difference because I do it all different times and I also don't bother to check if the wheel is locked or not.My car has not had any issues.
To when to shift to reverse?
