winter storage
Old Nov 18, 2006 | 03:45 AM
lilbilly's Avatar
lilbilly
1st Gear
Default winter storage
i just picked up my 2007 vette, in hopes of a few nice days to get her out and stretch her legs a bit i have not put it up on the lift yet, my question is
gm reccomends disconecting the battery for winter storage and while on charge, is there any reason for this other than that they state that after 30 - 40 days there is enough draw to drain the battery, i was planning on leaving it hooked up to a batery tender for the winter months, i have used them for years on motorcycles and have never had a problem, does anyone know of any reasons gm does not reccomend leaving the battery hooked up
Old Nov 18, 2006 | 04:33 AM
marshall5758's Avatar
marshall5758
I have used the small Battery Tender on my corvettes for the past 6 years and have no issues. They work Great....
Old Nov 18, 2006 | 07:23 AM
shortski's Avatar
shortski
No information in your profile on location, damn it people fill in your profile, the government know who you are anyway but up here in VT the temps can get to 20-25 below so it's not just a parasitic drain issue, or with the battery tender a charge issue, but a possibility of the battery freezing. Even with the battery tender I wouldn't take the chance of not having a power failure and then having the battery freeze. If you have a heated garage just start it up every week and sit and listen to some nice cruising tunes and let your imagination run wild. When in doubt follow the manufactures recommendations, after all they did design and build it.
Old Nov 18, 2006 | 08:05 AM
Wass's Avatar
Wass
St. Jude Donor '09-'11
I use a battery tender. No problems with it. While it gets extremely cold up here on the mountain, my garage temperature seldom gets below the 20's.
Old Nov 18, 2006 | 08:21 AM
JVM225's Avatar
JVM225
St. Jude Donor '06
I've been using a Battery Tender Plus for many years without a problem. I use the alligator clips and leave the battery connected.
Old Nov 18, 2006 | 09:02 AM
ProfMoriarty's Avatar
ProfMoriarty
Someone may know the reasons. I don't.
However, from a practical standpoint, you can leave the battery hooked up with a Battery Tender attached and it'll be fine.
Old Nov 18, 2006 | 09:07 AM
bocabob's Avatar
bocabob
This is my first winter with my C6... other than the battery issue, I was thinking of putting it up on blocks since I dont have a lift. Does anyone else block it up and put a cover on? Sorry if this sounds dumb, but just looking for ideas of the best way to store her..
Old Nov 18, 2006 | 09:09 AM
ProfMoriarty
For my garaged C6:
1. Fill gas tank and add Sta-Bil (7.5 oz.); run through fuel lines.
2. Change oil and filter.
3. Park on moisture barrier
4. Inflate tires to 38 psi cold.
5. Apply sealant, wax, etc. to exterior paint.
6. Apply leather dressing to seat panel.
7. Apply vinyl dressing to interior; and to exterior black trim pieces.
8. Hook up Batter Tender. Run wire into engine compartment from underneath car and duct tape exposed wire to floor so you don't trip over it and yank it out.
9. Crack windows a bit.
10. Cover with Wolf Dustop inside car cover.
11. Wait for Spring.
Old Nov 18, 2006 | 09:11 AM
bocabob's Avatar
bocabob
thanks prof!
Old Nov 18, 2006 | 09:49 AM
johnodrake's Avatar
johnodrake
Moderator
Old Nov 18, 2006 | 09:56 AM
johnodrake's Avatar
johnodrake
Moderator
I do similar to the Prof but fewer
Fresh oil and filter
Full tank and a can of fuel dry
Park it in the garage
plug in the battery tender in the aux power receptacle in the console
Put in a couple of desiccant bags
car cover on
Wait for spring
(I am always doing some projects over the winter so the cover comes off from time to time - I will apply Zaino two or three times over the winter and detail the interior.)
Old Nov 18, 2006 | 10:38 AM
JVM225's Avatar
JVM225
St. Jude Donor '06
I've been storing my GTO this way for about nine years:
I add Stabil and fill the tank.
Change the oil and filter.
Clean the car inside and out, and add a coat of wax/sealer.
Add an extra five PSI to the tires.
Park on a moisture barrier. (I park on a Park Smart, Clean Park Mat year round;this coupled with a painted garage floor really keeps the dust down too).
Hook up the Battery Tender Plus to the Battery with alligator clips.
I don't use a car cover! I usually dust with a Car Duster and wipe down with Quick Detailer whenever the car looks like it is starting to get a little dusty over the winter. I just never got around to finding a car cover that I like, I'm always afraid of scratching. Plus, I enjoy the bonding time that keeping my car dust free brings during the long winter months.
Come spring time I just unclip the Battery Tender Plus, start it up, back it out, and enjoy.
My C6 will be parked alongside my GTO in the garage this winter, and get the same treatment.
To winter storage
