A6?
Old Nov 21, 2006 | 04:38 PM
jas142's Avatar
jas142
4th Gear
Default A6?
How is the A6 paddle shift? Is it much slower than the M6? Can you hold gears until redline and does it shift somewhat crisply/quickly?
Old Nov 21, 2006 | 04:44 PM
Vette_DD's Avatar
Vette_DD
4 of the top 11 times for the 1/4 mile for forum members were set by A6 automatics. An A6 is only 0.126 seconds behind the fastest 1/4 mile and the trap speed is only 2 mph slower.
Bone stock
06C6FVR, Z51 ....12.23 @ 115.58 06
LS1LT1, Auto ..... 12.356 @113.66 06
DrRichie, Z51 .... 12.42 @ 113.9
David K, Z51 .......12.49 @116
Jschindler, Z51 .... 12.49 @ 114.9
Nine Ball, Z51 ..... 12.54 @ 113.24 (fan/stat mod)
Orange C6, Z51/auto .... 12.56 @ 112
Zippin Zee, Z51 .... 12.65 @ 111.65
Tony.96LT4, Z51/Auto .. 12.66 @ 113.45 06
Silverlx, Auto …….12.69 @ 112.0 06
Jelsis, Z51/Auto..... 12.70 @112.43 06
Old Nov 21, 2006 | 04:59 PM
UTVOL06's Avatar
UTVOL06
the shifting delays have been dramatically reduced in the 2007 model over the 2006 introduction version. It was merely a firmware update. Further plans to reduce the delay and improve the paddleshift are planned for the 2008 model as well. The paddles will let u hit 5800rpms from what I've herd..but I could swear I've hit higher and it never changed my gears or stopped me from changing...could they have allowed for higher rpms for the 2007 models?
Old Nov 21, 2006 | 05:05 PM
aaronfaby's Avatar
aaronfaby
Can the firmware in an 06 be updated?
Old Nov 21, 2006 | 05:07 PM
UTVOL06's Avatar
UTVOL06
I don't know some think so that have asked, but no one has given us a definite answer yet. Surely someone will post back on this. I know several are checking into it.
Old Nov 21, 2006 | 05:18 PM
SHOOTER 49's Avatar
SHOOTER 49
Mine is an 06 so I cannot speak to 07 improvements. But for the average driver the a6 left in S mode is rather quick and very easy to launch. Using the paddles on twisties is fun but the 06 does have a delay from hitting the plus button till it upshifts---but again we are told here that there is improvement on the 07. The manual is more fun and far more interactive with the driver. But with average shifting skills and launching skills the a6 is likely a quicker car in the hands of the mass mediocracy.
Old Nov 21, 2006 | 07:44 PM
glennhl's Avatar
glennhl
You can hit the rev limiter at 6400 rpm and it won't shift until you hit the paddle.
Old Nov 21, 2006 | 08:07 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Old Nov 21, 2006 | 09:21 PM
rayainsw's Avatar
rayainsw
Default 07 vs 07 response
I have about 800 miles on my 07 A6. ( Probably 750 of those in S w/ Paddles active. ) I test drove 2 06 A6s. I discern no appreciable difference between my 07 and those 06s in the response to paddle shift requests.
- Ray
Happy, in any case . . .
Old Nov 21, 2006 | 11:57 PM
SpiralCoupe's Avatar
SpiralCoupe
Originally Posted by Grumpy
Old Nov 22, 2006 | 12:03 AM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
I love my paddles!!!!!!!!!
Old Nov 22, 2006 | 12:04 AM
C6 MoneyPit's Avatar
C6 MoneyPit
St. Jude Donor '06-'07-'10, '15. '22-'23
How is it:
It's good.
Can you hold until redline?
No.
Does it shift somewhat crisply?
Not enough for my taste, but still good. I have an '06, I hear in '07 it is better.
Old Nov 22, 2006 | 12:18 AM
glennhl's Avatar
glennhl
I have a friend at work who has a 07 A6. I'd love to drive it to see if it has the same delay as my 06 A6, but I'm afraid he'd die of a heart attack if I nailed it in 1st gear and hit the paddle at 6000 rpm to see if it hits the rev limiter like mine does before it shifts. He still hasn't taken his over 3500 rpm yet.
Old Nov 22, 2006 | 12:22 AM
Lightning Coyote's Avatar
Lightning Coyote
Old Nov 22, 2006 | 01:58 AM
StarJack's Avatar
StarJack
Found that sucker once when I was in S mode and accidently pulled back on the paddle while getting on it.
Old Nov 22, 2006 | 10:53 AM
Black04Vert's Avatar
Black04Vert
If you're rude with the clutch and perfect in your shifts, a manual should have a slight edge over an auto most of the time. IMO though, the auto tranny shifting logic is purposely designed a little conservatively to allow for a smoother gear change and extend the life of the drivetrain. If performance were the only consideration and the tranny/TC were programmed accordingly, I'm not sure a human rowing through gears would be able to compete.
Without hijacking this thread, is the lockup on the TC programmable in any way?
Old Nov 22, 2006 | 10:59 AM
UTVOL06's Avatar
UTVOL06
Obviously Porsche has made there fully automatic Tiptronic paddle system faster than there manuals. If they can do it so can GM.
Old Nov 22, 2006 | 12:51 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
No.
Mine will easily hit the rev limiter if I'm too slow on the paddles, so yes, I can hold it to redline and slightly beyond.
Unless you mean "you must shift slightly before redline rpm so that the shift actually occurs at redline."
To A6?
