amber light not working...
Old Dec 17, 2006 | 01:22 PM
vette-oholic's Avatar
vette-oholic
Default amber light not working...
the one near the passanger side visor... im pretty sure its never worked... could i have it turned off?
Old Dec 17, 2006 | 01:28 PM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
I don't believe it can be turned off, but it is very dim. It may be switched by a light sensor and not be visible unless it's completely dark outside.
Old Dec 17, 2006 | 01:30 PM
calemasters's Avatar
calemasters
It is only on when the headlamps or parking lamps are on.
May not be visible in with ambient light. Inspect in the dark.
There is no dedicated swith for this lamp, other than the headlamp switch.
Old Dec 17, 2006 | 04:55 PM
caroutisine's Avatar
caroutisine
C5's worked the same way.
Old Dec 17, 2006 | 04:56 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
A lot of people don't want it on.
Old Feb 2, 2007 | 04:08 PM
vette-oholic
finally saw it on... woulda never noticed it if didnt know it was there
Old Feb 2, 2007 | 04:57 PM
1KUVETTE's Avatar
1KUVETTE
Yeah it's not very bright. Even when I change mine to the brightest Blue LED I could fine it's still barely visible.
Old Feb 2, 2007 | 05:43 PM
AtomicC6Vette's Avatar
AtomicC6Vette
That's funny this topic came up. My brother noticed the light on in the car the other night and i'd never seen it before. Thought something wasn't locked down on the roof or something for a minute.
Old Feb 2, 2007 | 07:33 PM
Lightning Coyote's Avatar
Lightning Coyote
Old Feb 2, 2007 | 07:47 PM
Sunnyvale Dave's Avatar
Sunnyvale Dave
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'19
I have seen questions in the Forum asking what the light does, but I have never seen mine on.
Old Feb 2, 2007 | 09:57 PM
Radical05's Avatar
Radical05
Default change it
Change it out to what ever color you want from Radio Shack. Did my LMB in blue.
Old Feb 3, 2007 | 09:00 AM
vette-oholic
just an LED? how does you change it?
Old Feb 3, 2007 | 09:25 AM
Radical05's Avatar
Radical05
Default LED light change out / Radio Shack
The LED that shines down comes from the passenger side visor mount/clip. If you take out the one screw (torx I believe) you will see the wire that goes to it. Gently pull about 2-3 inch max of wire out so you have room to get the LED out. The LED just pulls out. Radio Shack 276-316 is for the Blue LED. They have others. You will see when you get it the two stiff wires are longer than the one we have. Just match up and clip off the excess. Push it in the socket and you are done. Very easy.
Old Feb 3, 2007 | 09:31 AM
Radical05's Avatar
Radical05
Default Link to visor LED Removal
Go to this link and scroll down to #37. That has pics on exactly how the visor LED comes out and what you will see.
http://forums.corvetteforum.com/show...assenger+Visor
To amber light not working...
