Thermometer stuck
Old Dec 20, 2006 | 04:25 PM
own2vettes's Avatar
own2vettes
Default Thermometer stuck
For the past 2 days, my thermometer seems to be stuck at 75 degrees F. It has read this constantly since Monday. Tech gurus please advise.
Old Dec 20, 2006 | 04:34 PM
Bushong572's Avatar
Bushong572
I have the same problem on my '06.........75 degrees.
Old Dec 20, 2006 | 04:41 PM
pit-pony's Avatar
pit-pony
Where is the thermistor located in the C6? Somewhere in the grill area I suppose. Can you find it?
..jack
Old Dec 20, 2006 | 04:44 PM
SHOOTER 49's Avatar
SHOOTER 49
2 c6's and two very, very, very SLOW thermomiters to react. Takes 15/20 minutes but does eventually read correctly--or close to it.
Old Dec 20, 2006 | 04:50 PM
Zymurgy's Avatar
Zymurgy
Moderator
There are some delays designed into the outdoor temp display:
If the outside temperature goes up, the displayed temperature will not change until:
• The vehicle’s speed is above 10 mph (16 km/h) for five minutes.
• The vehicle’s speed is above 32 mph (52 km/h) for two and a half minutes.
These delays prevent false readings. If the temperature goes down, the outside temperature will be shown when you start the vehicle. If it has been turned off for less than three hours, the temperature will be recalled from the previous vehicle operation.
Old Dec 20, 2006 | 04:54 PM
Bushong572's Avatar
Bushong572
Mine has been stuck for a week.
Old Dec 21, 2006 | 04:19 PM
Bushong572's Avatar
Bushong572
bump......
Old Dec 21, 2006 | 04:30 PM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
Most likely it's a loose sensor wire or a bad sensor. I'd start by checking the wiring connection to the sensor. It's down low on the passenger side of the radiator shroud, IIRC. You could also try resetting the temp display by pulling the fuse to the climate control and reinserting it. If neither of those fix it, I'd take it to the dealer.
BigJoe's Avatar
BigJoe
I know thats what the manual says, but here in TX I get to work when the temp is say 60 and after work when the temp is 100+ the thermometer instantly says 100+ when I turn on the car. No delay.
Old Dec 21, 2006 | 04:41 PM
Zymurgy's Avatar
Zymurgy
Moderator
Mine does the same thing. I don't think the manual description is completely accurate. As long as mine car has been off for a while, it shows the current outside reading at start up. But I have also observed the time/speed thing.
Old Dec 21, 2006 | 05:11 PM
mpuzach's Avatar
mpuzach
Mine used to do the same thing. Dealer replaced the outside air temperature sensor and all is now well.
Old Dec 21, 2006 | 05:35 PM
VET4LES's Avatar
VET4LES
Same in San Clemente.
Old Dec 21, 2006 | 06:37 PM
calemasters's Avatar
calemasters
Maybe you're just having nice weather.
Old Dec 21, 2006 | 08:54 PM
knkali's Avatar
knkali
if the car is shut down for 3 or more hours the temp reading is instant.
After that the speed/time program takes over.
If stuck replace the 10 dollar sensor. I did and works accding to manual.
very poor design IMO
To Thermometer stuck
