Clicking brake pedal
This just started today. When Im in park and hit the brake I can hear a click comming from the shifter (Auto). I can feel it on the shifter a little as well. Any ideas?
I hear it in mine when the car is quiet inside. It is the relay letting you shift into gear when you apply the brake. Just a safety feature. Nothing to worry about.
I hear the same thing almost everytime I brake when it's quiet in the car.....07 A6 with 300 miles.....I thought I was nuts but apparently I'm not.....It's a small click that sounds like it's coming from down on the passenger side. Anyone have a clue?
It's normal..got it in my 07 A6 z51 as well. click!
The other clicks people are talking about are relays, stop lamp relay, starter interlock control relay, etc, and those are located under the passenger floorboard in the BCM. They're audible because the noise they make when they operate resonates in the A/C ducting. That's why they sound like they're coming from behind the dash. GM could have located them somewhere else, ie under the hood, or used solid state switches instead of relays, but they didn't.
