Convertible Trunk Dimensions??
Old Dec 28, 2006 | 02:04 PM
Rubber Ducky's Avatar
Rubber Ducky
Default Convertible Trunk Dimensions??
Anyone got the dimensions of the C6 trunk, top up & top down? (Yes, did search - found coupe but not 'vert.) Tks.
Old Dec 28, 2006 | 03:19 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
I had this floating around in a old email. I think its for a 06, but all should be real close. Its not quite what you asked for, but it should help.
There is a switch on this partition, that will not let you put the top down when the partition is not in place. With this partition down, the trunk measures 59" wide, 34" deep and 11" hide. When the partition is in place, the truck is 17" deep, with a little room up under the partition."***
Old Dec 28, 2006 | 04:32 PM
Vette_DD's Avatar
Vette_DD
They've published the total volume several times in the Corvette Quarterly, but I don't think I've ever seen the dimensions. They just say it's 10.4 cu. ft., without specifying whether that's with the manual top or automatic top.
Old Dec 28, 2006 | 06:02 PM
Flecker's Avatar
Flecker
I have 07 vert. Tell me again do you want length and width with top up and down?
The ad say's two golf bags fit and I know that to be true.
my son and I both take the vert and go play golf.
Old Dec 28, 2006 | 08:16 PM
PhotoLad's Avatar
PhotoLad
Hre is a thread with pics http://forums.corvetteforum.com/show...t+measurements
Old Dec 29, 2006 | 10:29 PM
PhotoLad's Avatar
PhotoLad
Default Wife thinks it's pretty big.......
........ but she refuses to use a tape measure
Old Dec 29, 2006 | 11:43 PM
KILR-Z51's Avatar
KILR-Z51
To Convertible Trunk Dimensions??
