Is there a way you can change the orange light that is on the passenger side next to the visor that shines on the center console. If you can what type of bulb does it take and how do I change it..
Very easy mod...5mm LED (blue LED is part # 276-316; various colors available) at Radio Shack. Remove passenger visor clip; LED socket pulls straight out. Do a quick fitment test for polarity then cut leads down to appropriate length before buttoning it all up. < 5 min total time.
why do you have to cut the leads to change the light?
The led I purchased had leads that were approx 1/2" long; you only need approx 1/8 - 3/16" ... unless you want the led projecting through the hole in the bracket. Use the original led as a gauge.
