Vert owners with power top......question????
I had some major problems with my 05 when I first got it. The cover fell on to the canvas and cut it and sometimes the top would get stuck half way down. Dealer fixed the problem with the actuaters and replaced the top. They even threw in a CD changer for my troubles. The top has worked without problems ever since.
If the top is down when the battery dies then you need to manually close the top to "wake up" the system. I didn't realize this the first time I disconnected the battery to do some stereo work and after puzzling my way through finding the pump etc I closed the top and then it worked fine.
Warren
I've got an '07 with 4,000 miles that rarely gets driven with the top up. Other than the wear that is occurring on either side of the headliner, I haven't had a single issue with the top or the mechanism.
Josh
Josh
Took delivery in June 05. Dealer has replaced about every mechanical part - meaning that I had problems with the top for several months. It has worked well for quite some time now and I really enjoy it. But it was a bit of a pita for a while.
