Interior LED light question
Old Jan 28, 2007 | 12:38 PM
  #41
achilds's Avatar
achilds
Originally Posted by Pipedreams
This is getting to complex for me: leaving: I have had mine in over a year and they are fine. Only in the garage you can see that a minute after the door is shut they dim down and are around 5% brightness and go completely out in a few hours. I have 4 PIAA bulbs. They already sell load eq's for LEDS:
"15-25 OHM DELUXE ALUMINUM
25 watt LED Load Equalizer
Corrects Most LED Related Turn
Signal Problems"
Thanks, I was looking for the aluminum packaged version. The point here is that they don't go off in a few hours. Unless your car is different or the PIAA LEDs are different either of which is probably not the case. They will stay lit because that is how the circuit works. At any rate the solution is to leave them alone or add the resistor. Both solutions are fine and will cause no problems.
