Another dead battery
Not to bust your bubble, but 3 weeks is just about the max a C6 battery will last. It all deepens on your battery’s general age/ condition to begin with. A lot of it could also depend on how much driving you did before you parked the car
AS you have no info in your profile, we do not know anything about your car. Year, tranny, when purchased, ETC.
Doubt your dealer will do much if anything for you If your going to leave your car, that’s ANY car for 4 weeks, brake down spend about $25 (Wally World) and get a tender
Car dead after being left for 4 weeks without starting is not DBS. Car left for <2 days with dead battery is. How many other cars have you left for 4 weeks and had them start right up. The cost of the car should have nothing to do with the need for a battery charger. I have my $60K car on a battery charger and mine starts right up. Seems to me if it works, why take the chance.
I think the fact that we have FOBs will cause a drain. There is an antenna and it's looking for the signal from the FOB. Seems to me it needs a smidge of juice to stay "looking" for signal. Whether it sees a FOB or not, it MUST continue to look.
Radio, something is holding the stations into memory. Sounds like another smidge of juice.
I'm sure there are other things sitting there at "hold" that require a smidge of juice (alarm system?) to remain ready for use.
Letting a car sit for 4 weeks is asking too much from any battery. Either hang a charger on it or drive it every 4 or 5 days and I bet it'll start just fine.
My $.02.
Elmer
Too much electronic mumbo-jumbo.
Smaller battery and charging system to save on weight and dollars.
3 weeks is it for a well maintained delco battery, otherwise you need a larger battery or charger.
Letting a car sit for 4 weeks is asking too much from any battery. Either hang a charger on it or drive it every 4 or 5 days and I bet it'll start just fine. Elmer
My 97 Intrepid, which hasn't been driven since August of 2005, started right up last week when I was showing it to a potential buyer. (That surprised hell out of me since I'd done nothing aside from parking it to properly store it for such a long time.)
OTOH, my old 78 F350 will kill the battery in 3 months if it isn't started. The aftermarket stereo is the culprit. It draws power all the time, not a lot, but enough to drain even the Optima battery in the truck if I don't drive it every couple of months. So I put a battery disconnect on it. I have to reset the radio presets when I fire it back up, but at least it will fire back up after sitting for a long time.
My $.02.
Elmer
I have two! two cars that sit in my garage while I drive my silverado all week. 1 is the 07 mr a6 vert which I drive only on clear weekend days and the other ismy 2000 Cadilliac SLS. Both Ac delco batteries. The caddy has 49K miles on it so you know it does a lot of garage sitting.I have found that only driving either car one day a week keeps the batteries charged and have had no start up problems,
Once a week is all it takes! Sometimes I do not drive the caddy for two or three weks but no longer as I do not want things to start those squeaky noises.
if i leave the c6 for a a few weeks without starting it...theres no way it'll fire up....the c5 i left for months on end and she used to have no issues firing up...(it was an 01 and it had its original battery with no issues)
