Has anyone else noticed a problem with the C6 2007 factory chrome wheels? I was cleaning the car today and noticed a spot that I could not clean off, on the front wheel. Upon closer inspection, it looks to me like it may have a bad chromed spot or something. It is appoximately 1/8 inch in diameter. I know it is not very big, but I noticed it when cleaning. I don't know if something like that would be covered under warranty. I will get a picture tomorrow if the sun is out. May be best to run it by the dealer. Although I did not buy from the local dealer.
Haven't had this particular problem, but the finish on inside of wheel is a constant source of irritation ... gets dirty; tough to clean. Thinking about exchange for set with fully chromed barrels.
Any Chevrolet dealer will honor your warranty. I bought my 2005 from a dealer 3,000 miles from home. My local dealer enjoys working on my C6. It additional income for them.
I heard that the aftermarket rims like those from WCC are much better then the factory ones. And 1/2 the price too.
Apples and oranges. OEM chromes are forged while WCC chromes are cast. That means major differences where it counts, namely strength and weight. I wish my OEM wheels had chrome on the inner barrels, but to me that's a minor annoyance. If WCC chromes met all the same specs as OEM chromes, I daresay their costs would be a lot closer.
Hope dealer takes care of your problem.
One of the guys here has applied paint remover to the inner barrel of OEM chromes with great sucess. I'll look for his thread, I told him it would be popular fix for the OEM's.
The flat grey paint can be removed, done by "Late Life Toy Lover" here
Hi - could you explain to me what the difference is between forging and casting rims, and what the end result is? in other words, which process results in a "better" wheel?
thanks,
Mark
Forging takes a rough cast blank and squeezes it into a die under high pressure (like minting coins). Casting is liquid metal poured into a mold (think iron skillets). Castings often contain bubbles, voids, cracks, and other imperfections that lead to uneven weight distribution and weak spots. Forging causes cast metal to partially melt, flow and reform into finer crystalline structures. Forging usually requires additional manufacturing steps like surface machining and heat treatment (annealing) to relieve internal strains. Forgings are lighter and stronger than cast replicas which have heavier, thicker cross sections and and may be comparatively brittle..
I'm confused WCC takes OEM wheels and has them chromed, probably by the best chromers in the industry. Why would the "forging" be different? They are OEM wheels with the GM markings on the inside. I checked before I returned my wheels and again when theirs arrived.
Oh and where does GM chrome wheels come from? The US or China?
I've been unimpressed with the factory chrome wheels on Vettes I've detailed. The finish isn't that great and the barrels are tough to get and keep clean since they are machined but not clear coated or anything. On cars I've detailed that took advantage of the WCC ecxhange program the wheels look great. The not so funny part is you could buy a set of take off painted rims and make the exchange with WCC and save money over the factory chrome option and still have a factory quality wheel.
