Build Sheet
Old Feb 12, 2007 | 09:08 PM
vietvett's Avatar
vietvett
5th Gear
Default Build Sheet
I ordered a build sheet from the national corvette museum but no where is the build date on the sheet that i can see unless it's in some code, any ideas ?
Old Feb 12, 2007 | 09:51 PM
cksrick's Avatar
cksrick
Call Betty at the NCM 1-800-538-3883 Ext.141 give her your vin# and e-mail address and she will send it to you.
Old Feb 12, 2007 | 09:56 PM
Vette_DD's Avatar
Vette_DD
Yep, no build date on the build sheet, per this post.
http://forums.corvetteforum.com/show...00&postcount=7
Old Feb 12, 2007 | 10:01 PM
VET4LES's Avatar
VET4LES
The only way I knew my build date was Kevin Terrance sent me an e-mail the day it came off the line. I'm sure they don't do that any longer.
Old Feb 12, 2007 | 10:12 PM
GMautotech's Avatar
GMautotech
I can get them too. Check the sig
Old Feb 12, 2007 | 10:20 PM
Forvettes's Avatar
Forvettes
Cruise-In VI Veteran
St. Jude Donor '05-'06-'07
I just looked at my build sheet and you are correct, no date. But I know the date because I drove it off the line.
Old Feb 12, 2007 | 10:27 PM
MADinAK's Avatar
MADinAK
St. Jude Donor '06-'07-'08-'09-'10,'14
PM sent. Thanks.
Old Feb 12, 2007 | 10:46 PM
su8pack1's Avatar
su8pack1
Old Feb 13, 2007 | 06:47 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
As was noted, there is no build date on the build sheet. The build sheet is a router used identifying the car, VIN and options to be installed. On some, there is a date and time stamp in the top right corner (you can see it in my picture). This is the date that the sheet was que'd up at the plant, not the actual build date. The timing can vary from a few days to a few weeks from that date. As an example, the date on my build sheet is 03/26/97 from my C5's build sheet. The car came of the line on April 15, 1997. Post your VIN number in a seperate thread and ask for your build date information. Someone with access to GM's VIS will surely run it for you. You build date will be contained in the the top few lines.
Paul
To Build Sheet
