Salt and rain
Old Mar 2, 2007 | 12:05 PM
JD21029's Avatar
JD21029
Default Salt and rain
I had to drive my Vette here in Maryland when they still had salt on the roads, and I'm a little worried about salt on my undercarriage. That stuff, if left alone, can be pretty corrosive. I guess I could find a place that does undercarriage washes, but I haven't had her through a car wash yet, and would like to avoid it if I can.
Question is, if I drive her in the rain, do you think the splash from the road will be sufficient to get the salt out?
And am I being too paranoid worrying about the road salt?
Old Mar 2, 2007 | 12:14 PM
PirateMatt67's Avatar
PirateMatt67
No, you're not paranoid at all. If you're like me, which it seems you are, I get crazy if rain hits the car or anything like that. It's a bummer you had to drive it with the salt present.
Old Mar 2, 2007 | 12:21 PM
JVM225's Avatar
JVM225
St. Jude Donor '06
Break out the hose and give it a good rinse.
Old Mar 2, 2007 | 12:23 PM
LJD51's Avatar
LJD51
From: North Strand, NMB, SC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
There has to be a drive thru, brushless car wash you can use in your area.
You will have to spring for the Ultimate/Grande/El Supremo wash in order to get the under carriage wash but it is well worth it.
I used the one near my house three weeks after I got my Vette when I ran over a dead deer laying across my lane; I had to go over it as I couldn't move the right (18-wheeler) or the left (no shoulder) and I knew not to hit the brakes (I would not have stopped in time and the deer would have gone right into the lower grille opening...).
I drove back and forth over the under carriage wash nozzles about ten times to get the blood, guts and fur off the car...
Old Mar 2, 2007 | 12:24 PM
speedmd's Avatar
speedmd
Originally Posted by JD21029
I had to drive me Vette here in Maryland when they still had salt on the roads, and I'm a little worried about salt on my undercarriage. That stuff, if left alone, can be pretty corrosive. I guess I could find a place that does undercarriage washes, but I haven't had her through a car wash yet, and would like to avoid it if I can.
There is a laserwash in Columbia that is all high pressure water with undercarriage spray. I haven't had any problems with my vette or other cars.
Old Mar 2, 2007 | 12:25 PM
IC6's Avatar
IC6
argh, sounds like a nightmare to clean up ... hose as much off as you can, if its fresh, but one trip in the salt is not going to corrode your undercarriage... i would be more concerned with cleaning things up to look nice again, if that's what you're looking for.. maybe you can get under there and wipe it off, the hose won't get it all, it'll leave a cloudy film on everything
Old Mar 2, 2007 | 12:26 PM
Vet's Avatar
Vet
Yes. Don't worry about it. I drove my car all winter last year when there was a decent amount of snow. I think I hosed down the underside just a few times the whole winter. This past summer while working under the car I noticed that the underside looked perfect, like new, zero signs of corrosion, etc. The salt had zero effect. Remember, it's a CAR, designed and meant to be DRIVEN.
If the car sees a LOT of salt, it's not a bad idea to try to hose down the inside of the wheel wells and the underside if and when you can. Since salt reacts with water, it's usually good to hose the car down on wet days if and when possible... since the car is already wet.
My wife's mint Mustang GT vert has already seen 5 harsh north-east winters... car is out on the roads every single day of every winter, in maximum salt, sand, etc... and I rarely get a chance to hose that car down because she's always driving it... has never seen a car wash, ever. The car is still in MINT condition, inside and out... looks SHOWROOM. See no corrosion underneath.
So... don't worry about the salt. Enjoy the car while you can. Every day you can take the car out for a drive, whether rain, salt, sand whatever, is a GOOD day. Enjoy and appreciate.
Old Mar 2, 2007 | 12:41 PM
HyperX's Avatar
HyperX
Veteran: Marine Corps
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
Todays cars will not corrode from salt like they used to. I drive mine around on salt roads and then just use a touchless wash to spray under. Not a spec of rust in 1 year of driving.
Old Mar 2, 2007 | 12:53 PM
SilverSurferC6's Avatar
SilverSurferC6
IT IS A CAR - GET OVER IT!!!!
Why bother owning it if you don't drive it. Jeeze, when are you folks going to understand that they make terrible "coffe table books"?
Old Mar 2, 2007 | 01:04 PM
dennis50nj's Avatar
dennis50nj
the rain will clean it i had trans fluid on the bottom and the puddles cleaned it all off
Old Mar 2, 2007 | 01:08 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Mine will never see snow or salt
Old Mar 2, 2007 | 01:21 PM
tseibert's Avatar
tseibert
Minnesota/Wisc elevates salt to a new level. Do any of you from the area recall the holes in your 1st high school beater? Life's to enjoy, but subjecting my car to that isn't my idea of fun...
Old Mar 2, 2007 | 01:52 PM
JD21029's Avatar
JD21029
Can you tell me where it is?
Old Mar 2, 2007 | 01:57 PM
shopdog's Avatar
shopdog
Plastic, aluminum, and stainless steel don't rust.
Old Mar 2, 2007 | 02:06 PM
speedmd's Avatar
speedmd
Here is the address:
9205 Berger
Columbia, MD 21046
It's near EZStorage that you can see from Snowden River Pkwy.
Old Mar 2, 2007 | 02:19 PM
JD21029's Avatar
JD21029
9205 Berger
Columbia, MD 21046
I know exactly where that is! Thanks! I'll probably hit it on the way home tonight.
Old Mar 2, 2007 | 02:24 PM
JD21029's Avatar
JD21029
I think you need to learn how to read. I drove it in the snow. I'm asking if driving it in the rain (which I do) will get the road salt off. Is it a problem to ask about the best way to get the salt off?
My Vette is my daily driver. I have 12,000 miles in less than a year.
To Salt and rain
Old Mar 2, 2007 | 03:09 PM
owebo's Avatar
owebo
St. Jude Donor '11, '16
The rain is what I am planning on to get the salt off of mine. Been driving all winter long every chance I could get...Rain, snow, salt, sand....all the good stuff that makes others skin crawl here!!! It is just that fun of a car!!!
Old Mar 2, 2007 | 03:22 PM
IC6's Avatar
IC6
"rock on"
salt and sand around here destroys cars. as it is, i have a hard time avoiding kicking up sand left on the road from the previous winter during the summer.
Old Mar 2, 2007 | 03:25 PM
User 020720's Avatar
User 020720
They use a sand mixture here in Texas which compared to salt I can't say is better or worse since sand can do a number blasting your front end. Either way you can't win, rain on the other hand as long as it's not that acid rain cr*p shouldn't be a big deal. Just don't sweat it and do the undercarriage wash like everyone suggested. Gotta love mother nature.
